What's wrong with Class-D? - Page 14 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 9th March 2013, 02:20 PM   #131
GoatGuy is offline GoatGuy  United States
GoatGuy's Avatar
I'm real late to this discussion, but for me these are the issues.
[1] Class D "synthesizes" the output waveform by blasting tiny pulses of power at variable width to a strip of high-current low-pass filters ... one hopes that the feedback circuitry is actually accomplishing the task of making a faithful output waveform viz a vis the input.
[2] #1 isn't in itself really all that bad, necessarily. Its like using teeny tiny jackhammers to carve wood. Thousands of them, simultaneously, so I hear. The results can LOOK like carved wood. The low-pass filters is the "sanding and buffing" that renders the carving smooth enough to let anyone think it was actually carved with awls, chisels, knives and manual labor. Sadly, it wasn't. Is this necessarily bad, especially "after sanding"? Dunno. Fear, uncertainty, doubt ... about the 'damage' caused to the waveform, should all that sanding not quite do what the design says it should do.
[3] RF and RFI - are a natural and inescapable consequence of the D method. All those little jackhammer pulses, positive and negative, have rise-times and fall-times on the order of dozens of nanoseconds (else, the D method wouldn't be anywhere near as thermally "efficient" as it generally is!). Hundreds of thousands of ultra-fast slew-rate pulses per second ... 1/P = F ... 1/100ns = 10 MHz ... there's going to be a lot of RF energy in that box.
[4] Because of #3, and because of a series of articles I read some years back where a researcher (Normal Korman) tracked down a not-so-subtle issue with RF and RFI interfering with the sonic purity of his amplifiers ... and on quashing ... replacing no other components than some wiring placement ... was bowled over listening to the same recordings, same equipment, same speakers, etc. RF/RFI was the culprit. And in the home-built and commercial Class D equipment ... is such RF/RFI suppression really all that effective? Ah... FUD perhaps, but the D stands not for digital, but doubt.
So, all I'm saying is - well, listen critically to it. if you're building your own, then make extra, extra special care in shielding all the input wires (coax from jack to board), and make sure the board layout totally isolates things. From having worked on a lot of MHz to GHz designs professionally, I wouldn't even think about implementing Class D without RFI "cages" on the output, to contain the RFI within a Faraday cage and prevent its leaking, unexpectedly, all over the place.
There you are.
GoatGuy
Old 9th March 2013, 03:08 PM   #132
Kindhornman's Avatar
GoatGuy,
You forgot the interaction with a smps power supply and the chance of switching remnants passing through to the amplifier and being mixed with the signal source along with its rfi that can also be injected into the system. I am not saying that all of these issues can't be overcome, just that they do add a layer of complexity to the entire picture besides every other analog issue that still exist like any other analog circuit.
Old 9th March 2013, 03:46 PM   #133
qusp is offline qusp  Australia
qusp's Avatar
Originally Posted by AP2 View Post
Just to conclude, on your statements:
capacitance multiplier: it is very far from what we have written, becouse is incapable of transient response. (or not know)
Nice smps: I do not know a single one that I can put in a big class AB and has a fast response to transients.
I agree on the batteries then!
regards
you are still disqualifying your very fast power supplies from being in the SMPS group? or you mean bigger amp than they can supply? its just a little bit of a confusing comment from the designer of the 'SMPS' that has the fastest response of any power supply I have seen with Class AB
Lead acid batteries as quiet power amplifier supplies? really? NOT. they are quietish with low constant loading, thats all, they are neither fast or quiet with high slewing high current demanding needs
some of the new battery tech is much better, but I would and do still post regulate or at least buffer with caps.
Old 9th March 2013, 03:51 PM   #134
Actually low pass in frequency domain means decimation in analog domain literally.
Analog->DSP->analog signal suffers interpolation artifacts in compare to original analog signal.
AFAIK Tektronix interpolation ICs for digital scopes is among some advanced NoHow for example. Wadia decoding computers is another sample of ramification that might be required "to restore" decimated Red Book PCM.
Old 9th March 2013, 04:00 PM   #135
xrk971 is offline xrk971  United States
xrk971's Avatar
There you are.
GoatGuy
The RFI is a good point, but how is 400 kHz + freq going to affect audible spectrum? Also, if leads from chip to LC filter is smaller 1/4 wave of 400 khz antenna, reduces emission. Shielded wire on input seems like a good idea in general for high impedance high gain inputs. I like your tiny jack hammer analogy, and I would say that given jack hammers the size of 400 grit sandpaper grains, the end result is the same.
Old 9th March 2013, 04:02 PM   #136
Why do we keep coming back to the statement that class D has to be in the digital domain? It can be done completely in the analog domain from what I understand, where is this dsp having to come from keep rearing its ugly head?
Old 9th March 2013, 04:47 PM   #137
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Oh, still trying to find the magic in something not measurable about audio waveforms that gets lost or dirty in PWM conversions or near a SMPS? Perhaps magic has more to do with expectations and human feelings, what about love? Personally I find more magic in setting up PA and mixing friend DJs and bands playing for friends, these are the origins of music.
I use to feel like the small child in The Emperor's New Clothes tale
Old 9th March 2013, 04:49 PM   #138
xrk971's Avatar
Good point. The only thing digital is the fact that FET switches on or off. There is no DSP.
Old 9th March 2013, 04:55 PM   #139
Analog means switching frequency is infinity.
Class D means switching frequency is below infinity usually within 200-500KHz.
Old 9th March 2013, 04:55 PM   #140
qusp's Avatar
more than that, Class D IS in the analogue domain, its an analogue technology, whether the modulator has digital inputs or not is beside the point
why do people continuously misunderstand/misrepresent this even here?
What is wrong? lumanauw Solid State 43 20th January 2013 06:39 PM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 08:52 PM
What am i doing wrong, why wont my JLH operate in class A / get warm? Shamron Solid State 63 12th November 2011 03:27 PM
PASS DIY F4 beaten hands down by my class D amp, what's wrong? mr_push_pull Pass Labs 98 31st May 2011 10:23 AM
Wrong Voltage / current on BoZ... or Wrong Measuring ? gionag Pass Labs 8 14th May 2008 11:24 AM
Copyright 1999-2017 diyAudio
