SMPS stiffener cap? - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 11th January 2013, 05:39 AM   #1
Hikari1 is offline Hikari1  United States
Default SMPS stiffener cap?
I am running a HifimeDIY T2 TK2050 w/ a sure 27V SMPS.
I've read a lot about adding a stiffener cap. I understand what it does but I am unsure how to implement it. The board already has a 10,000 UF cap on it, is adding a stiffener cap really needed or worth a shot?
Here's the amp:
Hifimediy T2 Mundorf
Here's the power supply:
SP-320-27 Mean Well | Mouser
Old 11th January 2013, 12:19 PM   #2
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
SMPS impedance is dominated by the control loop inside the power supply. Adding excessive capacitance will most likely unbalance it, making the impedance worse at some frequencies, or making it oscillate altogether. "Stiffener caps" have always been myths; even in automotive applications, it's hard to beat the internal impedance of a lead-acid battery.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 11th January 2013, 08:24 PM   #3
OK, understood. I do want to try adding a cap as it's easily reversible if I dont like it. You are probably right but it's worth a shot.
The back of the Meanwell is labelled:
+V, -V, ground, N, L
Right now the dc output is running to the amp from the +V and -V.
If I hook up a 50V, 2,200 uf cap between +V and ground on the power supply this should work, correct? The positive lead of the cap would go to +V and the negative lead to ground, correct?
Old 11th January 2013, 08:51 PM   #4
nigelwright7557's Avatar
Tim
Too much capacitance on the output of the SMPS can cause it to go into overload mode and switch off.
The smps will be running at hundreds of KHz so doesn't need big capacitors like a 50Hz system would.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk http://www.pcbcad51.co.uk
Survey: SMPS with or without stiffener cap? johnm Class D 13 12th January 2013 02:30 PM
Hypex SMPS DC Error detection and DC blocking cap bypass MaartenJ Class D 4 7th January 2011 10:58 AM
FULL BRIDGE SMPS: With or without poly cap in primary coil? CHACALPOWERS Power Supplies 4 9th June 2009 01:55 PM
Selecting coupling cap for half-bridge offline SMPS Pierre Power Supplies 21 23rd March 2007 07:09 PM
Copyright 1999-2017 diyAudio
