Sure TPA3122D2 Mods
Sure TPA3122D2 Mods
Old 9th January 2013, 01:29 AM   #1
prezden is offline prezden  Canada
Default Sure TPA3122D2 Mods
I have been trying to improve the Sure TPA3122D2 amp with the swapping out of some of the caps for others. As I am new to this sort of thing I would appreciate your comments on the changes I have made thus far:
C16, 17, 19, 20 to 1uF 50V Rubycon
C7, 8, 10, 11 to 470uf 35v Nichicon
C1, 2 to 1uF 275v Panasonic film
Old 9th January 2013, 01:33 AM   #2
I forgot to add- the sound is a lot better, especially in the lower ranges. Although the bass is still a bit weak.
Old 10th January 2013, 05:10 AM   #3
Nobody
Old 11th January 2013, 06:47 AM   #4
wushuliu is offline wushuliu  United States
wushuliu's Avatar
Experiment with different power supply caps and values like ELna Silmic, Panasonic KA, and Nichicon Muse. It's hard to tell what you are using from your pic. Don't know what the smaller caps are there, but if they are MKP or MKT I would suggest replacing with Wima film/foil FKP.
All should be available easily from mouser.
Old 13th January 2013, 10:56 AM   #5
Thanks wushuliu
It probably sounds pretty dumb but I am not sure which ones are the power supply caps.
Old 13th January 2013, 04:58 PM   #6
Bare is offline Bare  Canada
Usually the biggest ones :-) Fit New triple the UF (at least) ones or the biggest you can possibly fit, physical size being the operative limitation, for any hopes of a wee bit better bass.
I'm guessing that any improvements resulted from Adding the 2 film caps.
This isn't the ideal choice amp board contraption for amazing performance potentials.
But you should certainly try, regardless.
Old 13th January 2013, 06:38 PM   #7
Thanks Bare
I'm slowly working my way up to better boards as I learn.
I am going to replace the 4 1uF 50V Rubycon caps with 470uf 35v Nichicon so they are all the same. The first mods I made were to replace all 8 rail caps (is that the right name) with the Rubycons then I changed 2 of them for the Nichicon.
cheers
Old 13th January 2013, 10:53 PM   #8
killerbobjr is offline killerbobjr  United States
Put high quality film caps on LIN, RIN, and BYPASS (C1, C2, C14). This will be the biggest factor in improving sound quality. Replace C22 with a larger value electrolytic (100uF or so) and a small resistor (100-220 ohms) between VCC and C22. This will isolate the internal opamp stage from the switching stage.
For more bass, replace the C7/C8 and C10/C11 pairs with a 2200uF (8 ohm speaker) or 4700uF (4 ohm speaker) and make sure the power supply you plug into the board has at least double that value.
Old 14th January 2013, 10:18 PM   #9
Thanks guys
killerbobjr- Are you suggesting removing the1uF 275v Panasonic film caps on C1 and C2 and replacing them with new caps on L1 and L2?
How would that improve the sound over the film caps?
I am planning on using a 24v Meanwell for the ps. Is this a good choice?
cheers
Old 15th January 2013, 12:13 AM   #10
wushuliu's Avatar
Originally Posted by prezden View Post
Thanks guys
cheers
It's not clear what those caps are. It would help if you took a picture from another angle. It's difficult to see what you are already have.
Sure TPA3122D2 ModsHide this!Advertise here!
New TPA3122D2 Kit cervelorider Class D 2 4th January 2013 05:58 PM
Class D TPA3122D2 Single sided, all thru hole components Zaaphod Class D 12 22nd September 2011 02:51 PM
TPA3122d2 Amplifier Problem galaxy786 Class D 17 16th July 2009 04:42 PM
TPA3122D2 based amp just clicking and hissing along cynric Class D 6 11th July 2009 02:22 PM
Tpa3122d2 Class D Audio Power aris69 Class D 0 24th June 2009 11:50 PM
Copyright ©1999-2017 diyAudio
