Sure TPA3122D2 Mods
Sure TPA3122D2 Mods
Old 23rd January 2013, 03:13 AM   #21
prezden is offline prezden  Canada
Thanks killbobjr- your answers are very helpful.
Old 29th January 2013, 09:13 PM   #22
Well I have finally completed the mods for the 3122 and am ready to put it in it's wooden enclosure. Before I nail it down I would appreciate your comments / advice as to whether there are things that I have done wrong or things that I could do better.
Thanks for all your help
Old 26th February 2013, 04:28 PM   #23
glt is offline glt  United States
Default BTL
Nice thread and very useful for my project. Got a couple of these boards and plan on configuring them in BTL.
The first thing to change are the coils for the LC filter. According to the datasheet, I would need 22uH (the ones in the kit seem 10uH).
What would be a better choice: bobbin shielded type inductors or toroid type inductors?
Thanks in advance...
www.hifiduino.wordpress.com
Old 26th February 2013, 08:53 PM   #24
Originally Posted by killerbobjr View Post
... Replace C22 with a larger value electrolytic (100uF or so) and a small resistor (100-220 ohms) between VCC and C22. This will isolate the internal opamp stage from the switching stage.
Do you mean as an RC filter for VCC? (R in series with Vcc) Would ferrite bead work better?
Old 26th February 2013, 10:02 PM   #25
Default melted switch
By accident I melted the gain switch with my soldering iron . The gain is set too high. If I take off the switch can I simply use a jumper to reset the gain or do I need a new switch?
Sure TPA3122D2 ModsHide this!Advertise here!
New TPA3122D2 Kit cervelorider Class D 2 4th January 2013 04:58 PM
Class D TPA3122D2 Single sided, all thru hole components Zaaphod Class D 12 22nd September 2011 01:51 PM
TPA3122d2 Amplifier Problem galaxy786 Class D 17 16th July 2009 03:42 PM
TPA3122D2 based amp just clicking and hissing along cynric Class D 6 11th July 2009 01:22 PM
Tpa3122d2 Class D Audio Power aris69 Class D 0 24th June 2009 10:50 PM
Copyright ©1999-2017 diyAudio
