IGBT based class D amplifier
Old 6th January 2013, 12:55 PM   #1
muddasirwaheedmalik is offline muddasirwaheedmalik  Pakistan
Default IGBT based class D amplifier
Is there any way one can make use of IGBT power module like EUPEC FZ1200R12KL4C, its capable of 1200A and 7.8KW.
I have one and was wondering if one could use it to swap the output stage of class D amplifier ??? Target 2KW subwoofer amp.???
Old 6th January 2013, 01:26 PM   #2
maydaydeejay is offline maydaydeejay  United Kingdom
maydaydeejay's Avatar
Send a message via Yahoo to maydaydeejay
No, there's no way to adopt such IGBT's for amp output stage... reason being - these bricks are way too slow.
And I'm guessing, U don't have much experience ? 7.8k is the maximum dissipated power at 25deg.C. Not the abilities of transferring the power. If such bricks w'd be fast enough, then single brick (half bridge) w'd be capable of doing dozens of kW.
Old 6th January 2013, 01:46 PM   #3
alexberg is offline alexberg
alexberg's Avatar
It's probably good for 500A rms inverter which in turn yields 300 kW in bridge configuration. Fsw would be 10kHz max. Do you have hundred kW woofer?
EDIT driver for such a thing costs about the same as module itself - have fun if you got it for free...
Old 6th January 2013, 02:02 PM   #4
Zero Cool is offline Zero Cool  United States
Zero Cool's Avatar
the specs look quite interesting actually! very low total gate charge, switching times seem to be very fast, but what they don't list the On Resistance. In this case would be Rec (Rds for a mosfet) If the Rec is high, you will suffer a lot of loss and hence a lot of heat during the on transitions.
IGBT's i think were designed for switchers and inverter type applications.
It's not about what you can BUY...It's about what you can BUILD!
Old 6th January 2013, 02:17 PM   #5
...is it not what the Class D does ?
ok, ok, I know what U meant
Old 6th January 2013, 07:18 PM   #6
gmarsh is offline gmarsh  Canada
gmarsh's Avatar
Gate drive power and switching loss would probably make your class D amplifier less efficient than a class AB power amplifier at home audio levels.
Might be a fun device to have for induction heating experimentation.
Old 7th January 2013, 08:11 AM   #7
well. As i said the brick is with me and no other use. so can it be under modification with existing D class amps be used. and yes Cerwin Vega stroker pro can take 2KW. which is about the target.
Old 7th January 2013, 08:14 AM   #8
and efficiency is not a requirment here....its like how much difficult to get a lot of BJTs ...NPN/PNP...mounting...soldering.....runaways...and cost for equivalent amount of power. So brick is better option at the moment..
IGBT based class D amplifierHide this!Advertise here!
Interesting IGBT for class d... fredos Class D 47 29th December 2013 06:01 PM
Balanced IGBT for amplifier output Lazy Cat Solid State 183 1st August 2012 05:20 PM
igbt amplifier, real or fake ? Tekko Solid State 6 26th September 2010 10:26 AM
Giesberts IGBT amplifier Elektor 1995 kibi Solid State 9 20th December 2009 02:53 PM
Copyright ©1999-2017 diyAudio
