My class D amp - Page 9 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 27th January 2013, 02:23 AM   #81
abetir is offline abetir  Philippines
.ups just did my research..I found 2 pdf version, the other with the trimmer for frequency adjust.
Filter : T106-2 0.8mm wire @59Turns(@47uH). Is this connected by joining the tracks for 470nf & 1uf ?
Thanks!
Old 28th January 2013, 04:50 AM   #82
Hi sir manoj
how are you today ?
i try to creat filter for aud600 with etd29
i was try that with 2 wire 0.8 in same side for 70uh and 25uh.
when i did conect 25uh then filter get hot and amp not woked
why ?
thanks
Old 29th January 2013, 11:50 PM   #83
Hi!
Anyone with knowledge on class D amps...question here, can this inductor be used as alternative for 220uH choke coil on AUD600?
Thank You!
(I wonder why the contributor has gone silent, It's been a while, i'm currently collecting parts for AUD600...guess I needed guidance.)
Old 30th January 2013, 06:19 AM   #84
manojtm is offline manojtm  India
manojtm's Avatar
Hi abetir,
Yes you can use drum coil for low supply rails(max.+/-35V),220uH don't need for 250KHz fsw
MANOJ
Old 30th January 2013, 06:27 AM   #85
manojtm's Avatar
why ?
Hi Hadi,
Don't use second windings and I won't give you the TIPs now regarding for reducing EMI and THD+N.
Don't misunderstand me.
MANOJ
Old 30th January 2013, 07:08 AM   #86
Originally Posted by manojtm View Post
Hi abetir,
MANOJ
Hi Manoj,
..is it 220uH specific? Will a 100uH be able to work also..?
Thanks!
Old 30th January 2013, 09:29 AM   #87
Default thanks to sir manoj
Hi Hadi,
MANOJ
hi
thanks
as you wish
have nice day
Old 30th January 2013, 01:50 PM   #88
manojtm's Avatar
Hi abetir,
for 250KHz fsw use up to 70uH coil
MANOJ
Old 30th January 2013, 11:45 PM   #89
Hi abetir,
MANOJ
Thank you Manoj, I'll get back to you as soon as I have completed one board for a test..
I will be using these pair for the inductor...
Old 31st January 2013, 03:11 PM   #90
manojtm's Avatar
Hi All,
My new AUD600 supply +/- 65V fsw @425KHz IRFP250N Mosfet working good cool for mid volume for high little heat with small heatsink
MANOJ
TBJ's Class D - a discrete class D amp that anyone can build! (Work-In-Progress) tbj Class D 11 18th January 2017 08:49 PM
Leaving class A how to make this amp leave class A to AB when volume is increased? rhythmsandy Solid State 3 14th June 2016 02:16 AM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 09:52 PM
does class A amp feel more powerful with same ratings compared to class AB? rhythmsandy Solid State 7 10th December 2012 06:21 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 08:52 PM
Copyright 1999-2017 diyAudio
