My class D amp - Page 6 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 15th January 2013, 03:09 PM   #51
manojtm is offline manojtm  India
manojtm's Avatar
how much gap is good for ee type cores ?
Hi IR,
it depends supply voltage applied to the amp / max. 4mm gap and min. 1mm gap
MANOJ
Old 19th January 2013, 11:15 AM   #52
Originally Posted by manojtm View Post
Hi Max,
These are my old class d designs don't ask me the schematics(again go for searching my scratch papers)all parts are listed in the silks screen layout except post 22(1000W amp)that i will give you on PM if you are interested.
MANOJ
Please send my mail: as.rebachuck@gmail.com
Old 21st January 2013, 06:22 AM   #53
manojtm's Avatar
Hi Ravpreet,
my old simple tone control
MANOJ
Old 21st January 2013, 06:32 AM   #54
manojtm's Avatar
Hi ravpreet,
OUT R resistor 1K connected wrongly(connect to Vcc pin 8) cut the print line and connect to out 2 pin 7 use a small wire
MANOJ
Old 21st January 2013, 06:55 AM   #55
very very thanks
Old 21st January 2013, 12:37 PM   #56
pravpa is offline pravpa  India
Default AUD600 with sub crossover
Hi Prav,
Use my AUD600 with sub crossover
MANOJ
Manoj Sir,
I have gone through the forum and downloaded the necessary artwork for AUD600. I would like to know the total expenditure to make a budget (in Rs).
Pravin
Old 21st January 2013, 02:02 PM   #57
IRSound is offline IRSound  Germany
Hi Manoj,
what is the effect of gate resistor on mosfet dissipating power and fsw of amp ?
39 ohm gate resistor is good for 250~300KHz and IRFB4227 ?
Old 21st January 2013, 04:48 PM   #58
Vostro is offline Vostro  South Africa
Vostro's Avatar
Hi Pravpa, do you mind posting the artworks for AUD600,
Im also going to make this Amp, but finding all the details isnt made easy.
Old 22nd January 2013, 04:41 AM   #59
manojtm's Avatar
Hi IR,
gate resistor is very critical on high frequency side. MOSFET gate capacitor increases the resistor value decreases and gate current will increases
practically i found that freq.=300Khz=130nC = @1A and i don't know the calculation
another i found above 25 ohms gate resistor will give the stability (max.100R)
MANOJ
Old 22nd January 2013, 01:30 PM   #60
Thanks Manoj
please refer to this post :
Class D Amp with LM566,LM393 and 2XIRF530
TBJ's Class D - a discrete class D amp that anyone can build! (Work-In-Progress) tbj Class D 11 18th January 2017 07:49 PM
Leaving class A how to make this amp leave class A to AB when volume is increased? rhythmsandy Solid State 3 14th June 2016 01:16 AM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 08:52 PM
does class A amp feel more powerful with same ratings compared to class AB? rhythmsandy Solid State 7 10th December 2012 05:21 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
Copyright 1999-2017 diyAudio
