| Class D Switching Power Amplifiers and Power D/A conversion |
#41 | |
Use my AUD600 with sub crossover Regards MANOJ |
#42 |
Sir,
Thank you for you suggestion...expect for shematic and pcb with power supply, or provide me the link where I will get all details of AUD600 Regards, Pravin |
#43 |
Thank You for your suggestion...Please share a link for details of AUD600 with sub crossover. Regards, Pravin |
#44 |
Hi Manoj,
What is the differences between EE type cores (ER-ETD-EE,etc) and toroid cores in class-d application ? because i think when we replace toroid cores with ee types , zobel network resistor becomes more warm..is it true ? can we reduce output HF with suitable filter ? Regards |
#45 | |
not all toroid cores , only iron powder core with low AL value is good for class d(b'cause they have enough air gap) or toroid ferite core with 1.2mm gap is suitable for 500W RMS class d amp. Regards MANOJ |
#46 | |
Hadi will give you the link or you can search this forum "ucd-25-watts-1200-watts-using-2-mosfets" Regards MANOJ |
#47 |
Manoj Sir,
Thank You for reply...I will do the research.. Regards, Pravpa |
#48 | |
but i used ER42 with 1mm gap and it was so good , better than T130-52. how much gap is good for ee type cores ? Regards |
#49 | |
![]() you was started your AUD600 from page 266 and this is link ucd 25 watts to 1200 watts using 2 mosfets have nice time diyers |
#50 |
Thank you... Hadi Sir
Thank you ...Manoj Sir |
| Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) | danielwritesbac | Chip Amps | 206 | 19th January 2013 08:52 PM |
| Leaving class A how to make this amp leave class A to AB when volume is increased? | rhythmsandy | Solid State | 1 | 20th December 2012 08:12 PM |
| does class A amp feel more powerful with same ratings compared to class AB? | rhythmsandy | Solid State | 7 | 10th December 2012 05:21 PM |
| Configuring an AB class amp to work in pure A class | jrme | Tubes / Valves | 5 | 23rd February 2010 06:31 PM |
| Can a Class AB PP amp be said to be operating in Class A at low signal levels? | ray_moth | Tubes / Valves | 19 | 23rd January 2009 07:52 PM |
