My class D amp - Page 49 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 12th September 2013, 11:23 AM   #481
manojtm is offline manojtm  India
manojtm's Avatar
Hi opor,
You want high fsw @400KHz choose
AUD600 rev 1.1 with resistor 680R, 74HC04,IRFZ540,22uH(T157-2 or Coilcraft coil)supply rail +/-45V
MANOJ
Old 17th September 2013, 07:13 PM   #482
opor is offline opor  Thailand
Hi Manoj,
What happen with my amp ,AUD900? It can not run at fully level. Capacitor 0.4uf at LC filter is burned. I am using BD139,140 as totem and TIP31 with 13V zener as bias power. 2 pairs of IRFP4232 as output fets.
Regard
Opor
Old 17th September 2013, 07:21 PM   #483
Hi Manoj,
What happen with my amp,AUD900? It can not run at fully level. Capacitor 0.47uf at LC filter is burned. I am using BD139s,140s as totem. 2 pairs of IRFP4232 as output fets. TIP31 with 13vzener as bias power.
Opor
Old 18th September 2013, 08:28 AM   #484
manojtm's Avatar
Hi Manoj,
Hi OPOR,
use 474/400V for +/-85V supply and 474/600V for +/-140V supply(ie:: 4 times higher)
MANOJ
Old 19th September 2013, 04:04 AM   #485
aman khalsa's Avatar
Can any 1pls share aud900 pcb pls ......
Old 5th October 2013, 05:45 AM   #486
manojtm's Avatar
PCB ready for AUD1000SD
MANOJ
Old 28th October 2013, 03:32 PM   #487
manojtm's Avatar
Hi All,
waiting MMBT5401/5551 SMD,not completed yet.
sorry for the picture quality(mobile camera)
MANOJ
Old 11th November 2013, 10:07 AM   #488
manojtm's Avatar
Hi All,
3 mistakes found on my PCB after resolved this its working fine.HF clarity so good compare to my single side design(fsw=250KHz). EMI is very less.No noise
attaching my Volume limiter with clip and sig indicator PCB
MANOJ
Old 11th November 2013, 10:55 AM   #489
nice work sir........
Old 15th November 2013, 04:55 AM   #490
andrewlebon's Avatar
Hi Manoj
greetings which is your best AUD amp i want to try it feeling bored
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
TBJ's Class D - a discrete class D amp that anyone can build! (Work-In-Progress) tbj Class D 11 18th January 2017 07:49 PM
Leaving class A how to make this amp leave class A to AB when volume is increased? rhythmsandy Solid State 3 14th June 2016 01:16 AM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 08:52 PM
does class A amp feel more powerful with same ratings compared to class AB? rhythmsandy Solid State 7 10th December 2012 05:21 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
Copyright 1999-2017 diyAudio
