My class D amp - Page 44 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 30th July 2013, 10:19 AM   #431
manojtm is offline manojtm  India
manojtm's Avatar
My new dual layer work,not completed
any suggestions pls
Regarding
MANOJ
Old 30th July 2013, 01:12 PM   #432
stewin is offline stewin  Kenya
nice work. decided to go smd.
Old 31st July 2013, 12:18 AM   #433
any suggestions pls
Regarding
MANOJ
Nice all in one layout.
You decided to go SMD, since there's a lot of space maybe you should include totem pole buffer? and TO-247 mosfets? Gate drive should be 1/2W type. So that the DIYers can use higher current capable mosfets.
Also bridge rectifier is insufficient for high power. And the parallel relay for speaker protect is not good for class D because they will not turn on/off simultaneously. The speaker should be connected to ground when the relay is off so that when there's DC out and an arc is formed it will be redirected to ground and not to the speaker. Speaker DC protection with relays
Also put various LED indicators for easier troubleshooting.
amplifier PCBs and modules
Old 31st July 2013, 05:21 AM   #434
manojtm's Avatar
Hi Jlister,
Thank you for your good information regarding speaker protect. i will change the circuit and i feel relay paralleling not a big issue, i used a mosfet for driving relays(15Ax2 or 20Ax2).
High drive and inverter using normal IC(300mil)with base(for easy service) not a SMD one
Thank you stewin
MANOJ
Old 1st August 2013, 06:23 PM   #435
Location: Where the world's best tea come from:Kericho Kenya
Originally Posted by stewin View Post
hi all pictures of the smps
i added the primary turns so as to cool the outputs . i pushed it a bit hard without a heatsink both for the outputs ,the 7815,and the diodes rbv5006 and the mur1560 except a small heatsink to the mje350
Great work Stewin! Those pcbs look awesome, you've come a long way for sure.
if there are no sparks,it probably doesn't work!
Old 1st August 2013, 07:50 PM   #436
thanks man and welcome back . a much thanks also to GOD and the diy world for the support.
Old 3rd August 2013, 11:33 AM   #437
aman khalsa's Avatar
hello sir manoj .. can u pls share ur aud 1000 ??
Old 5th August 2013, 06:17 AM   #438
manojtm's Avatar
Hi Aman,
obviously i will do but it was an old carrier based design huge EMI and little noise.delta sigma design is good.
MANOJ
Old 5th August 2013, 06:20 AM   #439
hi manoj have you ever connected 4 aud600 amps with a single power supply(same power supply e.g one +/-75 for the 4 chanels )? and did they work perfectly even though one channel was disconnected from load/speaker?
ucd 25 watts to 1200 watts using 2 mosfets
Old 5th August 2013, 06:37 AM   #440
manojtm's Avatar
AUD600 rev1.1 x 3Nos(AUD600 amp and AUD600 power) connected with DC +/- 72V /20A(AC 52v-0-52v/20A) supply rail no problem found.
MANOJ
TBJ's Class D - a discrete class D amp that anyone can build! (Work-In-Progress) tbj Class D 11 18th January 2017 07:49 PM
Leaving class A how to make this amp leave class A to AB when volume is increased? rhythmsandy Solid State 3 14th June 2016 01:16 AM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 08:52 PM
does class A amp feel more powerful with same ratings compared to class AB? rhythmsandy Solid State 7 10th December 2012 05:21 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
Copyright 1999-2017 diyAudio
