My class D amp - Page 42 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 10th July 2013, 11:27 PM   #411
thanks for the reply manoj and jles.
Old 17th July 2013, 06:26 AM   #412
manojtm is offline manojtm  India
manojtm's Avatar
UCD(Credit:-Tekko worked) with Volume control,Balanced Input,OC & Limiter
MANOJ
Old 20th July 2013, 09:15 AM   #413
panos1 is offline panos1  Greece
hi manoj
can you give me part list and circuit of your aud1000 amp?
Old 20th July 2013, 03:21 PM   #414
aman khalsa's Avatar
Default ready in stock
ready in stock IRFB4227 and IRFP90N20D ... any one interested to buy ... then PM me.. thank u
Old 22nd July 2013, 05:51 AM   #415
manojtm's Avatar
Hi Aman,
Can you tell me the Price and how i order/pay
MANOJ
Old 22nd July 2013, 06:42 AM   #416
stewin is offline stewin  Kenya
hi aman i already sent you a pm . i am also interested
Old 23rd July 2013, 09:43 AM   #417
manojtm's Avatar
New Dual layer AUD1000SD and AUD1000UD coming!!!!!!!!!!!
MANOJ
Old 23rd July 2013, 02:00 PM   #418
NMOS is offline NMOS  Germany
NMOS's Avatar
Hi Manojtm
look schematic PDF File
BIAS 12V with TIP41C from -VCC, ZPD 12V 10K to GND does this work with AUD600 ?
Old 24th July 2013, 04:58 AM   #419
manojtm's Avatar
Hi NMOS,
yes it will work (for fsw=250KHz and above it will heat 90 degree)
For Higher rails use separate 12V/2A BIAS supply
MANOJ
Old 24th July 2013, 02:27 PM   #420
NMOS's Avatar
Originally Posted by manojtm View Post
Hi NMOS,
MANOJ
I dont like separate 12V Bias supply, if use
Transistor 2SC5200 NPN - 15A - 230V - 150W Power dissipation
it will be safe for 110V Rail ?
TBJ's Class D - a discrete class D amp that anyone can build! (Work-In-Progress) tbj Class D 11 18th January 2017 07:49 PM
Leaving class A how to make this amp leave class A to AB when volume is increased? rhythmsandy Solid State 3 14th June 2016 01:16 AM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 08:52 PM
does class A amp feel more powerful with same ratings compared to class AB? rhythmsandy Solid State 7 10th December 2012 05:21 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
Copyright 1999-2017 diyAudio
