My class D amp - Page 30 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 12th May 2013, 08:16 AM   #291
akraj is offline akraj  Bangladesh
Originally Posted by stewin View Post
thanks akraj for the spirit of diy .
have you managed to test it?
PCB may come to hand by this week.
Old 17th May 2013, 08:20 AM   #292
manojtm is offline manojtm  India
manojtm's Avatar
Hi All,
AUD600 Rev1.1 with IRF540 MOSFET and Coilcraft filter, Supply rail +/-45V amazing power
i feel proud on AUD600 and it will give same power (my feel) on 45v supply no need 75V rail
MANOJ
Old 17th May 2013, 09:51 AM   #293
stewin is offline stewin  Kenya
wow nice work. i am working on combining the main amp and protection in one board. i will use double sided board to reduce emi.
i will post the development later.
i will use irfb4227 as outputs.
Old 17th May 2013, 10:04 AM   #294
Originally Posted by manojtm View Post
Hi All,
MANOJ
Hi Manoj: how come coil can contribute for power outpost? I mean that huge difference? 45v and 75v is huge dirrerence.
What is the fsw?
Raj
Old 18th May 2013, 12:48 AM   #295
andrewlebon's Avatar
Hi Manojtm
greetings #292 nice coilcraft filter any part no how does it compare to T157-2
filter nice work
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
Old 20th May 2013, 07:09 AM   #296
manojtm's Avatar
What is the fsw?
Hi Raj,
using coilcraft filter with IC7404 fsw= 325KHz;IC 4069 fsw=205KHz and IC7414 fsw=110KHz
i want fsw=400KHz so i will change MOSFET IRF540 to other one
not actual watt, i said it was my feel
MANOJ
Old 20th May 2013, 07:15 AM   #297
manojtm's Avatar
Hi Manojtm
Hi andrew,
thanks. sound quality and power is good compare with T157-2 and very very low RF noise
Disadvantage is it will warm like 55/65 deg. temp with in 25 min. run and fsw will reduced to 280KHz(recheck again due to coil OR 74hc04)
can you tell me where i can get IRFP4227 MOSFET???
MANOJ
Old 20th May 2013, 07:21 AM   #298
Hi Manojtm
greetings thanks for replying
warm regards
andrew lebon
Old 20th May 2013, 12:22 PM   #299
exflaco is offline exflaco  Armenia
Please post the exec from pic thanks
Old 23rd May 2013, 04:07 AM   #300
manojtm's Avatar
any one tested Fairchild FDP075N15A_F102 MOSFET
MANOJ
TBJ's Class D - a discrete class D amp that anyone can build! (Work-In-Progress) tbj Class D 11 18th January 2017 08:49 PM
Leaving class A how to make this amp leave class A to AB when volume is increased? rhythmsandy Solid State 3 14th June 2016 02:16 AM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 09:52 PM
does class A amp feel more powerful with same ratings compared to class AB? rhythmsandy Solid State 7 10th December 2012 06:21 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 08:52 PM
Copyright 1999-2017 diyAudio
