My class D amp - Page 22 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 26th March 2013, 02:07 PM   #211
manojtm is offline manojtm  India
manojtm's Avatar
For -/+95 supply which components should be changed? Can I use irfp250n?
Hi Raj,
IRFP250N will work @4R load only.Not support short circuit, 2R load and Bridge
use 250V 80A Mosfet for safe @+/-95V supply range
MANOJ
Old 26th March 2013, 05:13 PM   #212
great work ......manoj sir
Old 27th March 2013, 07:49 AM   #213
adamkaktus's Avatar
Manoj, how about FDA59n25 or 60 A transistors? 80 A is a must? there is IRFP4768 but seems to be very expensive(about 5 times according to 59n25), maybe we shoul search something like 80n25 series?
Old 27th March 2013, 06:29 PM   #214
adamkaktus's Avatar
i can have:
IXFH100N25P 5,47 EUR/1 pcs exl. VAT, min. 30 pcs in 2-3 weeks
IXTH76N25T 2,68 EUR/1 pcs exl. VAT, min. 30 pcs in 2-3 weeks
but this is not cost-effective i think, maybe its easier to use two pairs?
FDA59n25 cost is about 1,25 EUR including VAT. and they are widely avaible from 1 PC. what do you think about it?
i Have another question.
Power board is unconventional, and somebody would like to use SMPS for this amp, what would be difference between this powerboard in that option?
Old 30th March 2013, 10:37 AM   #215
manojtm's Avatar
Hi Adamkaktus,
use IXFH100N25P or 2x FDA59N25
there is no issues using SMPS or Linear Power supply
MANOJ
Old 1st April 2013, 07:08 PM   #216
stewin is offline stewin  Kenya
Originally Posted by manojtm View Post
Hi ALL,
My AUD600 Rev 3.0.1 Power Board Shematic
MANOJ
hi sir manoj. what about the amp schema?
and what can i do to eliminate rf noise at high frequencies when it is playing loud . but issue occurs when using two channels . maybe it is because i never used 220uh inductor at aux 12volts for powering ir2110 ic.
Old 3rd April 2013, 12:22 PM   #217
manojtm's Avatar
Hi stewin,
did you ground the heat-sink(IRF250N Mosfet) with 1R or 10R resistor??
and Power GND should be in one point or good shielded GND
AUD600 ver3.0.1, after testing i will post
MANOJ
Old 4th April 2013, 08:06 PM   #218
adamkaktus's Avatar
Hi Manoj, i've bought few fda59n25 for test, but i will wait for new version. Can i replace 5551 and 5401 with mpsa 42/92?
Old 5th April 2013, 04:06 PM   #219
aman khalsa's Avatar
Default best class d ever made ... :)
thank u sir manoj for ur amp. very clear and good sound .. 22uh inductor @+/-63vdc .irfp250n no heat sink fets on 55degree .
can need any changes for +/-140 vdc .??? i n not useing 220uh for aux 12v.
Old 5th April 2013, 08:52 PM   #220
akraj is offline akraj  Bangladesh
Congrats, what type of core you are using? How many turns you gave?
It seems that you are not using 47R and 104 caps, any reason?
TBJ's Class D - a discrete class D amp that anyone can build! (Work-In-Progress) tbj Class D 11 18th January 2017 08:49 PM
Leaving class A how to make this amp leave class A to AB when volume is increased? rhythmsandy Solid State 3 14th June 2016 02:16 AM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 09:52 PM
does class A amp feel more powerful with same ratings compared to class AB? rhythmsandy Solid State 7 10th December 2012 06:21 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 08:52 PM
Copyright 1999-2017 diyAudio
