My class D amp - Page 18 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 4th March 2013, 06:04 AM   #171
manojtm is offline manojtm  India
manojtm's Avatar
Can I use TL074 to replace 072&071?
Hi Raj,
Yes you can use TL074
MANOJ
Old 4th March 2013, 10:24 AM   #172
manojtm's Avatar
Hi ALL
AUD600 wired for SUB WOOFER RMS1400W@4R
EQ for aud600 wired 100Hz sub filter
MANOJ
Old 4th March 2013, 01:21 PM   #173
akraj is offline akraj  Bangladesh
Originally Posted by manojtm View Post
Hi ALL
MANOJ
Hi Manoj:
What would be the max output voltage at speaker line from AUD600? If given max rail voltage?
Raj
Old 4th March 2013, 03:30 PM   #174
manojtm's Avatar
Hi Raj,
i didn't check the speaker voltage,before filter its shows 16.2Vpp(supply +/-75V) square wave on DSO with 10x probe.
MANOJ
Old 6th March 2013, 11:32 AM   #175
manojtm's Avatar
Hi Raj,
Transfomer AC Voltage is 53.1V and DC supply rail +/-71.5V current 10A volume level is up to clip indicator blinking point; check speaker voltage @27VAC. Clip indicator steady and bright point; speaker voltage @31.6VAC {speaker point connected 5R 50W resistor and it is too hot and burning smell coming tested @5min.}
from this you can calculate the out put watt
@27V AC means 27pp = 729W RMS @ clip point
@31.6V = 998W RMS
MANOJ
Old 6th March 2013, 01:14 PM   #176
Default Class D amplifier with high performance and crystal oscillator
Good morning everyone.
My contribution to the forum.
Have ridden with separate PCBs (clock / PWM audio input, power and protection).
I am now making a single PCB to finalize the project.
OK testing and operation.
Regards to all.
Old 6th March 2013, 01:45 PM   #177
Bigun is offline Bigun  Canada
Bigun's Avatar
Looks interesting luizcpimenta, would be great to see some photos of your pcb when it's ready.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 6th March 2013, 04:54 PM   #178
Regards to all.
thanks for the schematic luiz.
Old 6th March 2013, 09:17 PM   #179
OK.
Old 7th March 2013, 06:09 AM   #180
manojtm's Avatar
Hi luizcpimenta,
this is similar AUD1000C, thanks for new design. i will give you little correction for your design
1. Remove R129(1K5)
2. separate +15v supply for CD4060 for 12MHz switching it will take more current.
3. Re adjust R127 & R128 for PWM signal 3.3V level otherwise your Q103 will damage on long run(+B=75V or more)
MANOJ
TBJ's Class D - a discrete class D amp that anyone can build! (Work-In-Progress) tbj Class D 11 18th January 2017 08:49 PM
Leaving class A how to make this amp leave class A to AB when volume is increased? rhythmsandy Solid State 3 14th June 2016 02:16 AM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 09:52 PM
does class A amp feel more powerful with same ratings compared to class AB? rhythmsandy Solid State 7 10th December 2012 06:21 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 08:52 PM
Copyright ©1999-2017 diyAudio
