| Class D Switching Power Amplifiers and Power D/A conversion |
#151 | |
Later i contacted with INFANTRON (S) PTE LTD, I guess they are reliable. |
#152 | |
Plz Check on this http://www.cds.co.za/store/T200 Last edited by pravpa; 22nd February 2013 at 07:19 AM. Reason: link was wrongly pasted |
#153 | |
#154 | |
freestyle |
#155 | |
0.8mm wire Regards MANOJ |
#156 |
#157 |
Hi Raj,
find EPCOS sotre ETD39 you can use @23Turns 1mm gap all Regards MANOJ |
#158 |
Hi Raj,
you have ETD39(N87) center 1mm gap one, use 15Turns only @45uH Regards MANOJ |
#159 |
Hi All,
Any suggestion for this. anyone tested like this .it will work or not if i go with HCPL0723??? ![]() ![]() Regards MANOJ |
#160 |
Hi, ALL
pls comment ![]() ![]() ![]() Regards MANOJ |
| Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) | danielwritesbac | Chip Amps | 206 | 19th January 2013 08:52 PM |
| Leaving class A how to make this amp leave class A to AB when volume is increased? | rhythmsandy | Solid State | 1 | 20th December 2012 08:12 PM |
| does class A amp feel more powerful with same ratings compared to class AB? | rhythmsandy | Solid State | 7 | 10th December 2012 05:21 PM |
| Configuring an AB class amp to work in pure A class | jrme | Tubes / Valves | 5 | 23rd February 2010 06:31 PM |
| Can a Class AB PP amp be said to be operating in Class A at low signal levels? | ray_moth | Tubes / Valves | 19 | 23rd January 2009 07:52 PM |
