My class D amp
My class D amp
Old 5th July 2013, 07:16 AM   #391
manojtm is offline manojtm  India
manojtm's Avatar
Pre filter feedback selfosc = Class D done WRONG! (BAD design)
Post filter feedback self osc = Class D done RIGHT! (Good design)
Hi Tekko,
Its only a marketing Technics. No one is 100% perfect design.
My AUD600 = crystal clear sound, no noise,and better power output.
MANOJ
Old 5th July 2013, 07:40 AM   #392
Tekko is offline Tekko
Banned
And its limited to one single load impedance without changing the output filter = bad!
Old 5th July 2013, 08:54 AM   #393
syaelend is offline syaelend
Originally Posted by manojtm View Post
Hi Tekko,
MANOJ
Hi Mr. Manoj,
On your AUD600 ver 3.0 you use PIC629, is it a micro controller ic? what does it used?
Syaelend
Old 5th July 2013, 08:55 AM   #394
Banned
I guess overcurrent sensing and dc on output for speaker protection.
Old 5th July 2013, 09:06 AM   #395
don2007ksa is offline don2007ksa  Philippines
Hi Tekko,post filter feedback run's at hotter output coil inductor,please share a schematic (UCD POST FILTER F.B.)to give it a try,thank's.
Old 5th July 2013, 09:16 AM   #396
Banned
Heating of the inductor has nothing to do with topology, but has to do with the inductor itself like core material, heating is a sign that the material is not ideal.
My UcD class d project does not heat the inductors at all when o use the one from coilcraft for the zetex class d.
I'd share my schematic but considering how expensive the MAX913/LT1016/AD8561 comparator is, its not really practical and i have not been able to find suitable readily available replacements.
Old 5th July 2013, 09:57 AM   #397
manojtm's Avatar
Hi Syaelend,
AUD600 Ver1.0,1.1,3.0 & 3.0.1 donot using PIC629(PIC microcontroller)
MANOJ
Old 5th July 2013, 10:01 AM   #398
manojtm's Avatar
Hi Tekko,
You mean Post filter feedback will change fsw when you change load impedance or fsw constant and only effect NFB ( Audio freq. stabilization ) and THD
MANOJ
Old 5th July 2013, 10:08 AM   #399
ChingTan is offline ChingTan  Philippines
ChingTan's Avatar
Send a message via Yahoo to ChingTan
hi manojtm can you post where i can get your official aud600 3 is it free for diy?
Old 5th July 2013, 10:31 AM   #400
Banned
Hi Tekko,
MANOJ
I switched between open circuit and 0.8 ohm load on my ucd class d in BTL mode yesterday and the switching freq dident even flinge, it stayed on ~360kHz and did not move.
The problem with pre filter feedback self osc as several have outlined is that if the amp is made for 4 ohms, then at 8 ohms the freq response will increase as a spike at higher frequencies, whilst it may not be audible to most its still unacceptable as it means the amp is unstable.
Likewise a amp made for 8 ohms will start rolling off at early as 5kHz with a 4 ohm load.
While on UcD (post filter fb selfosc) the frq response barely changes at all from 0.5 ohms(some car subwoofers) to unloaded, it never starts spiking/peaking at higher freq like pre filter fb does.
My class D ampHide this!Advertise here!
TBJ's Class D - a discrete class D amp that anyone can build! (Work-In-Progress) tbj Class D 11 18th January 2017 07:49 PM
Leaving class A how to make this amp leave class A to AB when volume is increased? rhythmsandy Solid State 3 14th June 2016 01:16 AM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 08:52 PM
does class A amp feel more powerful with same ratings compared to class AB? rhythmsandy Solid State 7 10th December 2012 05:21 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
