My class D amp
My class D amp
Old 9th June 2013, 08:33 PM   #341
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
1/ Join all the audio ground together.
2/ Join all the power supply grounds together.
Take track from the audio ground to the edge connector where ground comes in.
This now the star ground point.
Take a track from the power supply ground to the same point.
Words explain it better than a picture.
I have used this technique on 4 audio systems now and never had a hum problem.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 9th June 2013, 09:14 PM   #342
stewin is offline stewin  Kenya
thanks nigelwright
Old 9th June 2013, 09:43 PM   #343
Tekko is offline Tekko
Banned
I did something like this on my latest UcD prototype and despite beeing a bit of a mess on a piece of prototyping board, it so far has the lowest noise floor yet.
http://i.imgur.com/pW980Gx.jpg
http://i.imgur.com/0B48NDu.jpg
Old 10th June 2013, 04:14 AM   #344
paskal9 is offline paskal9  Malaysia
paskal9's Avatar
also it might a good idea to isolate the audio ground (signal ground) to power ground with a small value resistor.
hum (usually) won't be a problem if you work with 2-3 channels but the possibility of humming shoots up with >4 channel in a single case. in my experience at least.
Old 10th June 2013, 07:13 AM   #345
i very much agree with you on that point .many amps i have assembled, when i use more than two channels class d i have serious noise issues . untill i change my layout or i remove preamp circuit if i am using one.
Old 10th June 2013, 01:54 PM   #346
exflaco is offline exflaco  Armenia
Two or more chennels Stewin 25khz ferq diference betwen channels ,or exact the same freq oscilattor (external sincro)
Old 10th June 2013, 08:18 PM   #347
two channels three or four of identical class d. ucd or non ucd also same challenge with discreet class d
Old 17th June 2013, 11:50 AM   #348
manojtm is offline manojtm  India
manojtm's Avatar
Hi Manoj,
Please give me more details.
You said it is 1000 watts - now is it stereo or mono ? Sorry I didn't read the whole thread.
You have said the voltage is 45V - is that AC or DC. Now you said you reduced it from 75 to 45. I am rewinding a Microwave transformer, so I can do either, just need a ampere rating.
Let me look through the thread for all other information. And I saw you said it sounds great. Compare the type of sound to something I might know - I have lots of vintage pioneer, marantz, yamaha etc etc. I also have listened to a bunch of newer receivers. Yamaha DSP3090 etc etc.
So You could say its like a pioneer sx 880 but has more power. That would be fine.
And how much shipped to USA.
Thanks.
Srinath.
Hi Srinath,
(a) completed working AUD600 Power AMP Board(IR MOSFET with COILCRAFT Filter),AUD600 Power Board,Signal&Clip indicator board,Volume control with limiter and Balanced input jack.(without transformer)(supply rail DC Min. +/-35V max. +/-47V) Price $180 shipping charge extra.
(b) completed working AUD600 Power AMP Board(FDA MOSFET with COILCRAFT Filter),AUD600 Power Board,Signal&Clip indicator board,Volume control with limiter and Balanced input jack.(without transformer)(supply rail DC min +/- 45V max. +/-70V) Price $185 shipping charge extra.
Spec
(a) Power FTC RMS 8R @275W
Power FTC RMS 4R @550W
Power FTC RMS 2R @1000W
(b) Power FTC RMS 8R @600W
Power FTC RMS 4R @1200W
Power FTC RMS 2R @2450W
MANOJ
Old 21st June 2013, 02:30 AM   #349
ravpreet420 is offline ravpreet420
Today test all version of AUD600
crystal clear sound ,powerful.
all version of AUD600 working.
no issue with 74hc04,
version 3.0 & ver 1.1 working ...
thanx manoj sir
regard
Old 21st June 2013, 07:29 AM   #350
manojtm's Avatar
Thank you ravpreet
MANOJ
My class D ampHide this!Advertise here!
TBJ's Class D - a discrete class D amp that anyone can build! (Work-In-Progress) tbj Class D 11 18th January 2017 07:49 PM
Leaving class A how to make this amp leave class A to AB when volume is increased? rhythmsandy Solid State 3 14th June 2016 01:16 AM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 08:52 PM
does class A amp feel more powerful with same ratings compared to class AB? rhythmsandy Solid State 7 10th December 2012 05:21 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
Copyright ©1999-2017 diyAudio
