My class D amp
My class D amp
Old 13th April 2013, 03:23 AM   #241
aman khalsa is offline aman khalsa  India
aman khalsa's Avatar
I m using IRFP250...
Old 13th April 2013, 05:09 AM   #242
manojtm is offline manojtm  India
manojtm's Avatar
Hi AMAN,
IRFP250N can handle up to +/-122V supply and do not connect 2R & 4R load. only for 8R load.
MANOJ
Old 13th April 2013, 10:59 AM   #243
Ok thank u sir.. with IRFP 260 can I drive 4 ohm 600w lord on +- 120v.
Old 13th April 2013, 12:25 PM   #244
norazmi is offline norazmi  Malaysia
+- 120 vdc is more than 600w at 4 ohm load.
Old 13th April 2013, 12:36 PM   #245
manojtm's Avatar
Hi Aman,
+/-120V you will get True RMS 1800W@4R load and use Speaker 4R/3600W for full drive
+/-71V you will get True RMS 600W@4R load
MANOJ
Old 13th April 2013, 02:29 PM   #246
Thank u sir.
Old 13th April 2013, 06:11 PM   #247
akraj is offline akraj  Bangladesh
Hi Manoj:
For last few months I was experimenting on your aud600 ver1. Today mistakenly I gave .1uf cap and instantly 2k/2w resistor blown away. Replaced that and removed .1uf with 1uf cap.
But there is no audio even no grid. Replaced all ICs but no response. All relative voltage is okay, relay connects, no overload nothing unusual. Still no response.
How and what I can check? I don have oscilloscope. Please suggest.
Raj
Old 14th April 2013, 08:28 AM   #248
Didi u chek 12vdc aux.??
Old 14th April 2013, 10:06 AM   #249
Yes, I checked. All relative voltage are okay.
Old 14th April 2013, 11:24 AM   #250
manojtm's Avatar
Hi Raj,
May be your relay blown.check your relay contacts
MANOJ
My class D ampHide this!Advertise here!
TBJ's Class D - a discrete class D amp that anyone can build! (Work-In-Progress) tbj Class D 11 18th January 2017 07:49 PM
Leaving class A how to make this amp leave class A to AB when volume is increased? rhythmsandy Solid State 3 14th June 2016 01:16 AM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 08:52 PM
does class A amp feel more powerful with same ratings compared to class AB? rhythmsandy Solid State 7 10th December 2012 05:21 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
