My class D amp
My class D amp
Old 28th February 2013, 05:18 AM   #161
akraj is offline akraj  Bangladesh
Originally Posted by manojtm View Post
Hi, ALL
pls comment
MANOJ
This is very cleaver design. However, mounting in box may be difficult. What is the rail voltage? and what FET you are using?
Raj
Old 28th February 2013, 08:28 AM   #162
manojtm is offline manojtm  India
manojtm's Avatar
Hi Raj,
Vertically mounting. 5mm thick aluminium and 3 inch Hight,6.5 inch length
+/-75V 10A DC rail and FET used IRFP250N fsw@250KHz. OC protect @18A
MANOJ
Old 28th February 2013, 08:57 AM   #163
Hi Raj,
MANOJ
Hi Manoj:
Is this version 3.0? So far I can recall your latest design was calibrated to work 500KHz.
Raj
Old 28th February 2013, 09:53 AM   #164
manojtm's Avatar
Hi Raj,
yes ver 1.2 PCB and modified to ver 3.0
you can go up to 480KHz for this you need a good mosfet. i like 200-250KHz range it is good for old generation MOSFETs without any problem.
MANOJ
Old 28th February 2013, 10:58 AM   #165
Hi Raj,
MANOJ
Hi Manoj:
Can I use TL074 instead if 072&071? It will save pcb space and another free opamp can be used for protection.
Another issue, is it possible to replace 7404 & 555 with a micro controller?
Your comments are highly appreciated.
Raj
Old 28th February 2013, 06:14 PM   #166
Hadighorbani is offline Hadighorbani  Iran
Hi raj
i think micro controler is not fast enofe for porotection
CPX say to me this before
in class D amp we need a way that must be very fast to shutdown the mosfet driver IC and mosfets
sir manoj can help to you beter
have nice time my friend
Old 28th February 2013, 06:35 PM   #167
Originally Posted by Hadighorbani View Post
Hi raj
After a long time Hadi!
Thanks for your reply. I was just wondering why an uC running @20MHz is not fast enough! to protect / trigger OC?
Besides, uC can also detect DC volts at Spk line without much component. This can be very good if uC is able to serve those purposes.
Raj
Old 1st March 2013, 04:24 AM   #168
hi my friend
i am so busy and i have many work for doing in my factory in last days off year
i am not electronic man
my best net friend CPX sayed to me the micro controler can not be fast enofe for doing protected
the dc voltage in amp out put is diferent voltage
some time 1 volt and some time 15 volt
new xmega can work with 3 volts and old 5 volts
what about AC volt in output of amp?
micro maybe damage
i dont test this before
i say before sir manoj can help you beter than me
have good day and do your job good and dont search the net bad boy when you are in work
Old 1st March 2013, 09:32 AM   #169
manojtm's Avatar
Hi Raj,
You cannot replace comparator(7404) with micro but you can use micro for DC,OC & TEMP protect,, ALC(limitter) also.
MANOJ
Old 1st March 2013, 09:59 AM   #170
Hi Raj,
MANOJ
Thanks Manoj.
Can I use TL074 to replace 072&071?
Raj
My class D ampHide this!Advertise here!
TBJ's Class D - a discrete class D amp that anyone can build! (Work-In-Progress) tbj Class D 11 18th January 2017 07:49 PM
Leaving class A how to make this amp leave class A to AB when volume is increased? rhythmsandy Solid State 3 14th June 2016 01:16 AM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 08:52 PM
does class A amp feel more powerful with same ratings compared to class AB? rhythmsandy Solid State 7 10th December 2012 05:21 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
