My class D amp
My class D amp
Old 19th February 2013, 03:17 PM   #141
manojtm is offline manojtm  India
manojtm's Avatar
Hi Raj,
T157-2 i purchased from amidon inc. USA 20pcs @INR-6,050.00
This is the best core suited for AUD600
MANOJ
Old 19th February 2013, 03:28 PM   #142
manojtm's Avatar
Hi ALL
using T157-2 @40uH coil.Perfect for LF MID & HF crystal clear sound fsw @213KHz, No other noise
MANOJ
Old 20th February 2013, 08:04 AM   #143
ChingTan is offline ChingTan  Philippines
ChingTan's Avatar
Send a message via Yahoo to ChingTan
hello manojtm what is max rail voltage of this amp?
and what is the max watts this amp can give?
Old 20th February 2013, 10:43 AM   #144
akraj is offline akraj  Bangladesh
Hi Manoj:
I have rectified the issue. Beside I tried to include 12V BIAS regulator in the amp board.
Can you please check whether it is okay or not?
Raj
Old 20th February 2013, 11:04 AM   #145
Originally Posted by manojtm View Post
Hi Raj,
MANOJ
Hi Manoj:
are they fake?
Find All China Products On Sale from Dong Guan Yang Tong electronics CO.,LTD on Aliexpress.com - MICROMETAL IRONG POWED CORE t157-2,T157-2MICROMETAL IRONG POWED CORE Free shipping,Promotion T157-2 Irong ferrite and more
Ran
Old 21st February 2013, 02:26 AM   #146
ChingTan's Avatar
i'm not an expert but it looks like fake to me the color is bright red unlike the original color is dark red
my friend already try bright red t-130-2 it heat that cannot touch it when he buy original with color dark red the heating is gone
Old 21st February 2013, 02:33 AM   #147
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
HAVE you tried any other core the core that detex audio uses
warm regards
andrew lebon
"It's Better to try and fail than to never know and always wonder"
Old 21st February 2013, 03:04 PM   #148
manojtm's Avatar
warm regards
andrew lebon
Hi andrew,
tested with ETD29 @23turns 1mm gap all,
Result EMI little high, LOW and MID best HF good. full volume(1v1 pp signal) MOSFET little HOT(55degree @30min. test)and coil hot @40degree. +/-75V supply full drive down to +/-73V
tested with 157-2 core @52turns
EMI Very low, LF,MID & HF best @full drive no heat coil and MOSFET 30min test.+/-75V supply full drive down to +/-73.6V
MANOJ
Old 21st February 2013, 03:10 PM   #149
Hi Manojtm
greetings do you have any simple audio limiter circuit in which output voltage can be set
warm regards
andrew lebon
Old 21st February 2013, 04:01 PM   #150
manojtm's Avatar
warm regards
Hi andrew,
use this
ucd 25 watts to 1200 watts using 2 mosfets
MANOJ
My class D ampHide this!Advertise here!
TBJ's Class D - a discrete class D amp that anyone can build! (Work-In-Progress) tbj Class D 11 18th January 2017 08:49 PM
Leaving class A how to make this amp leave class A to AB when volume is increased? rhythmsandy Solid State 3 14th June 2016 02:16 AM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 09:52 PM
does class A amp feel more powerful with same ratings compared to class AB? rhythmsandy Solid State 7 10th December 2012 06:21 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 08:52 PM
Copyright ©1999-2017 diyAudio
