My class D amp
My class D amp
Old 4th February 2013, 02:01 PM   #101
pravpa is offline pravpa  India
lycanlk Please check ypur PM.
Pravpa
Old 4th February 2013, 04:35 PM   #102
lycanlk is offline lycanlk  Sri Lanka
Pravpa
I'm sorry friend, I don't have any of my past project files since my portable hard disk was stolen by muggers in Croydon, UK. So I lost everything. I came back to Sri Lanka a few months ago and started DIY projects again.
Anyway I will search those project files in my friends PC. If I'd be lucky I will share those for you all.
cheers!
Old 5th February 2013, 03:50 AM   #103
de Ocampo is offline de Ocampo  Philippines
de Ocampo's Avatar
Originally Posted by manojtm View Post
My AUD600 Rev3.0 is suitable for any type of filter core like T106-2,ETD,EE & EI core with gap and supply voltage range will support like +/-35V to +/-85V and IRFP250N will support fsw up to @500KHz range with cool.my only problem was HF little low (using ETD,EE,EI with gap)compare to LOW and MID,but it is satisfactory.I am not started the PCB yet.
MANOJ
Hi Manoj,
This sounds very promising...guess I'll have to wait for rev. 3.0 then, but please let us know if it will be shared for DIY'ers in the forum.
Thank You!
Old 5th February 2013, 07:09 AM   #104
manojtm is offline manojtm  India
manojtm's Avatar
Hi ALL,
My AUD600 Rev 1.1 change to Rev 3.0
First test fsw @460KHz with IRFP250 MOSFET run cool with Mid Volume temp 50 deg. with full drive @ 4 Ohms load.
MANOJ
File Type: jpg AUD600Rev1.1 IRFP250 small H.sink copy.jpg (696.2 KB, 1281 views)
Old 5th February 2013, 01:59 PM   #105
aman khalsa is offline aman khalsa  India
aman khalsa's Avatar
nice work sir....
Old 5th February 2013, 02:56 PM   #106
Default AUD600 Rev 1.1 change to Rev 3.0
Hi ALL,
MANOJ
Manoj Sir,
Pictures of your Amp shows that your work is very neat and clean.
Great Work Sir !!!
Pravpa
Old 5th February 2013, 03:30 PM   #107
IRSound is offline IRSound  Germany
Nice work Manoj..
what is the main difference with your prevision designs ?
if it's possible , please give schematic to me. i'm working lots of month on class-d , still don't find a reliable design to improve and pcb designing.
Old 6th February 2013, 05:38 AM   #108
Hadighorbani is offline Hadighorbani  Iran
Congratulations m friend
nice work
Old 6th February 2013, 07:49 AM   #109
manojtm's Avatar
Hi Manoj,
use accurate LCR meter to measure the value of your inductor. maybe your ee type filters don't have enough inductance to reach a good cut-off freq. also as i calculated before , in lower loads , we lost some higher frequency and we should increase cut-off freq.
Hi IR,
Thanks. I changed cut-off freq. settings ; add a 474/400v capacitor now HF is good.
MANOJ
Old 6th February 2013, 09:54 AM   #110
Manoj,
for best result @4ohm , use 18~20uH + 470nF , the cut-off freq should be higher than 50KHz. but this values are not very good for 8 Ohm loads.
My class D ampHide this!Advertise here!
TBJ's Class D - a discrete class D amp that anyone can build! (Work-In-Progress) tbj Class D 11 18th January 2017 07:49 PM
Leaving class A how to make this amp leave class A to AB when volume is increased? rhythmsandy Solid State 3 14th June 2016 01:16 AM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 08:52 PM
does class A amp feel more powerful with same ratings compared to class AB? rhythmsandy Solid State 7 10th December 2012 05:21 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
