Bottlehead Quickie Tube Hybrid Class D Amp
Old 18th December 2012, 12:15 AM   #1
cervelorider is offline cervelorider  United States
cervelorider's Avatar
Default Bottlehead Quickie Tube Hybrid Class D Amp
[IMG]Click the image to open in full size.[/IMG]
This is a battery powered Bottlehead Quickie 3s4 tube preamp that I converted into a tube hybrid Class D amplifier that runs completely off the grid. I replaced the two inputs with binding posts and made the output the input. I affixed a Sure Electronics 3110 Class D board on the front, close to the volume pot. I added a voltage divider to the inputs of the Class D board. I added a dc input which uses a 12 volt SLA battery to power the Class D amp board.
The Quickie's are $100 and the Sure boards are $10. Add the binding posts and it is a fairly inexpensive experiment.
Old 18th December 2012, 04:20 AM   #2
Davet is offline Davet  United States
That is a really sweet set up. I'm really impressed with your ingenuity.
I run a Bottlehead Foreplay version 1 preamp. It is heavily modified and it drives various T-Amps: Trends 10.1; 41 Hz Amp6; Helder 2020 and 2024 based T-amps; and A Helder STA508. Which amp I use is based on which amp has the latest tweak.
Great job.
Davet
Old 22nd December 2012, 02:55 PM   #3
Great job.
Thanks Davet. If you want another winter project, I can highly recommend this board. I'm just starting to experiment with different caps, but the stock ones sound wonderful. I prefer this 3122D2 to my Tripath 2024. Bass is better and a bit more warmth.
DIY Electronics KAA03021 Kit
Bottlehead Quickie Tube Hybrid Class D AmpHide this!Advertise here!
25W Class A Hybrid Amp popilin Tubes / Valves 43 5th November 2016 07:50 PM
Bottlehead Quickie sippy Analog Line Level 4 8th October 2011 01:55 PM
Class A Tube BJT Hybrid jerluwoo Tubes / Valves 33 17th October 2006 10:04 AM
Tube Hybrid 25W Class-A, Opinions? Algar_emi Tubes / Valves 16 21st April 2003 11:24 PM
Copyright ©1999-2017 diyAudio
