| Class D Switching Power Amplifiers and Power D/A conversion |
#11 |
I would think 1 mfd would be enough. Bigger is okay, but not required. A decent quality film type will sound better then a electrolytic.
#12 |
I've just about finished my first project with this little amp and have one small problem. On start up it makes some clicking sounds through the speakers. When I turn it off them on again the clicking is gone.
Any idea why it would do this? ps: I am planning on implementing to the cap changes on the second board; have to order the caps. |
#13 |
I don't have experience with that board. It may be normal for that chip when it first powers up. You could add a delayed relay to disconnect the speakers for a few seconds when the amp is powered up, but that's more work. I would only worry about it if it looks like its hard on the speakers when it happens. Do the speaker cones move excessively in or out when the click happens?
#15 |
You have to invert the signal to one channel. If you're not using a balanced source then you have to build a separate circuit for this or use a transformer. I suggest just using one of their other ICs if you want bridged outputs.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
| TPA3122 doesn't work | Joku | Class D | 35 | 19th November 2011 02:07 PM |
| TPA3122 - not working. Nothing | aviatorbja | Class D | 17 | 26th July 2011 06:10 PM |
| TPA3122 | aditya | Class D | 2 | 10th April 2011 10:23 PM |
| TPA3122 for driving external MOSFET's | Cyberzim | Class D | 2 | 23rd April 2010 11:22 AM |
| TPA3122 Groundings | Cyberzim | Class D | 6 | 18th September 2009 11:28 PM |
