New and compact TA2020 board - opinions?
Old 3rd December 2012, 07:09 PM   #11
Thor Ra is offline Thor Ra  Denmark
Originally Posted by Bare View Post
IMO there's No need to go to overpriced input caps, as I discovered
(tripped over That the silly 1$ each yellow film caps sound better than Mundorfs in one of my ta 2020's.
Dunno why actually, maybe the higher esr of the cheapies?
Ain't that counterintuitive and contrary to Internet Folklore :-)
Regardless, they definitely sound better.
Experiment (widely) for best result.
Thanks. Do you have a link to the ones you are using?
Old 4th December 2012, 09:15 PM   #12
I did a little searching and it seems the stock 2.2uF electrolytic caps are "audio grade" Nichicons (from Japan). Perhaps these are not horribly bad after all? Any experiences?
Maybe I'll just wait and see how it sounds with these before I start tweaking.
Old 9th December 2012, 04:16 AM   #13
prezden is offline prezden  Canada
Please let us know how these little guys work out
Old 11th December 2012, 05:00 PM   #14
Bare is offline Bare  Canada
It's my opinion that most of the 'brand name' parts fitted to a ~$20 amp are Fakes.
Sometimes passable fakes often not.
Chinese makers are becoming quite adept at making their stuff 'look' as of quality.
Old 12th December 2012, 02:47 PM   #15
Davet is offline Davet  United States
Default Cap Correction
After reading Bare's latest post, I re-read this thread. In my earlier post regarding tank caps was based on the photo of the YJ amp not that of the electrolytic input caps of the small board.
Bare's comments regarding input caps should be heeded. Film caps in the DC Blocking application (input caps), generally, yield better sonic results over that of electrolytics. There are a number threads regarding modifying T-Amps and all sorts of input caps have been tried. The consensus seems to be the extra expense of the boutique caps just doesn't seem to measure up. YMMV.
Only your ears in your system will tell you which cap works best for you.
Please, let us know how you fair in swapping out these electrolytics.
Davet
Old 12th December 2012, 05:20 PM   #16
Redshift187 is offline Redshift187  Canada
Agreed. Electrolytics being the obvious candidate, but also output filters on a lot of these cheap amps have caps that look like film, but are likely ceramic, and ceramic caps in filters are not a good idea (their value changes with the voltage applied across them, and in filters that voltage is always changing).
Tyler
Old 14th December 2012, 02:07 PM   #17
redkid is offline redkid  United States
heck
for $20.00 I ordered one to play with.
Old 14th December 2012, 03:24 PM   #18
xrk971 is online now xrk971  United States
Got Foam?
xrk971's Avatar
It's a nice looking package with lots of room for upgrading with thru hole components and not having to deal with the manual dexterity required to mod surface mounts. Where is a good source for upgrading the input caps to $1 film caps?
New and compact TA2020 board - opinions?Hide this!Advertise here!
Need opinions for a TA2020 multimedia build. cadakus Parts 0 10th June 2011 09:09 PM
Any opinions on this ebay TA2020 board by seller auspicious.e? nkx1 Chip Amps 4 5th March 2010 03:52 AM
a few questions about this TA2020 board fishline Class D 35 24th January 2009 07:44 PM
Tripath TA2020-020 6 Channel Amp Board john65b Swap Meet 0 10th October 2005 01:20 PM
Tripath TA2020-20 6 Channel Amp Board john65b Class D 1 21st September 2005 05:43 AM
