SystemD_2kW, any interest for an open design?
Old 26th November 2012, 07:50 AM   #41
Workhorse is offline Workhorse
Workhorse's Avatar
Try FZT series also, you already have good ones with you, where is my diwali gift old man?
Old 26th November 2012, 09:08 AM   #42
Ouroboros is offline Ouroboros  England
Ouroboros's Avatar
Originally Posted by pergo View Post
some DIP comparators with <30ns propagation delay
The first is the cheapest.
LM306
AD8561
LT1016
MAX903
TL3016 from TI. Works well for me and has slightly improved parameters over the LT1016 (with which it is pin compatible).
Old 26th November 2012, 11:06 AM   #43
Workhorse's Avatar
TL3116 is much better with common mode range extending to negative rail.
Old 26th November 2012, 11:07 AM   #44
phase_accurate is offline phase_accurate
I have thought about some way to control the hysteresis: Markus and I were already in contact privately about this and I will try to sim it and if it "works" I will post details.
I don't know however, wheter soemeone else has already used the same principle already. One can never be sure nowadays - just make a patent search for class-d and you'll know what I mean.
Charles
Old 26th November 2012, 11:47 AM   #45
Ouroboros's Avatar
Thanks Workhorse, I wasn't aware of that one. I use the TL3016 with +/-5V supplies so the c-m range isn't all that important, but the 3116 might be useful in the future.
Old 26th November 2012, 04:47 PM   #46
ChocoHolic is offline ChocoHolic  Germany
Great !
This sort of busy thread is making me feel better.
...ohps and is bringing me to the situation that I might not be able to handle all input properly....
@manojtm:
I am also wondering why a totem pole driver should cause noise.
Have a look to posting #27. The figures there are all derived with an amp design that uses a BJT totem pole gate drive.
Ok the MosFets there were just half as heavy as the IRFP4668, but still heavy.
IRFB4115 driven from FTZ853/953 and IRS20957.
IMHO the noise figures are far better than average.
Do you have even higher spec demands? I mean, I need a headphone plugged directly to the speaker output in order to hear the noise at all.
I don't think that totem pole drivers cause generally noise, but it would be interesting to dig for the very detailed trouble mechanism, which caused issues in your experience. Such know how avoids to get trapped by the same pit falls.
Could it be that the faster switching caused more HF-ringing and in consequence more NF-noise? I am seeing in your design from the 25-1200 thread, extremely slow gate drive, which most likely is good for EMI and will also calm down the HFjunk-to-NFnoise conversion of the comparator, but most likely such slow switching impacts THD.
With this thread here, I am not aiming for THD levels as in posting #27, but I don't want to worsen it more than 20db. And idle noise should not worsen more than 10db.
The downside of faster switching is that you cannot get away with mini snubbers. I am sure that I cannot go with such light snubbers as your design. I am expecting more that I need 1nF and something between 5-10 Ohms. ...and of course will have to live with about 1.5W snubber losses.
Old 26th November 2012, 07:03 PM   #47
LM306: PropDelay is 28ns. Stoneagedesign. I like it. Available in DIP8 at DigiKey.
AD8561: To much of high speed high end. But at least available at as DIP8 at DigiKey.
LT1016: Also faster than I love. Available as DIP8 at DigiKey, Bürklin and Reichelt.
Max903: Again pretty fast, TTL output, not available at any of my daily sources.
TL3016/3116: Again very fast, not available in DIP8 at all, SMD available at Digikey.
My favorites would be LM306 and LT1016. Unfortunately they have pretty different PIN connections.
Any comments on personal taste and availability in other parts of the world?
Old 26th November 2012, 09:43 PM   #48
pergo is offline pergo  Italy
pergo's Avatar
i always use LT1016 (soon i will try the AD8561 as upgrade) with good results. No audible noise. But i never go over 350kHz switching frequency.
In my experience, it needs hard decoupling between rails and good layout.
All these comparator are sold by RS or Mouser.
Old 26th November 2012, 09:49 PM   #49
The floating input stage of the IRS20957 does not need to be connected to GND. It could also be bound to -8.25V in example.
This would allow an ultra simple discrete comparator as shown in the attached schematic. Not sure if this thing already deserves the name comparator, but basically it seems to work reasonably good even with standard components.
The low gain causes an additional delay. With the concerned signals it takes about 60ns until the differential input signal is large enough to generate a comparator output which crosses the flipping point of the IRS input (comp out ramps in approx 120ns).
Impact on idle frequency is still moderate (less than 10kHz).
I have to check for impacts on performance like distortion and frequency control by dynamic hysteresis....
Don't wonder about my strange voltages like 1.65V, 3.3V or 8.25V.
They can easily be derived from a chain of red LEDs ==> low noise zener substitute.
An upgrade with much more comparator gain could be the second schematic, still I am not convinced that the extra efforts are worth it. But it simulates nice. Sloping with the concerned input signals takes 30ns, delay just a few ns (hard to believe).
Please also note the inspiration from Workhorse combined with my improvement to move the mirror to a neg voltage and clamping which avoids saturation of the BJTs.
Old 26th November 2012, 10:04 PM   #50
pergo's Avatar
i made something similar.
Which is your switching frequency with IRS in your schematic?
I cannot get over 315kHz.
I've replaced the input PNP with BSS84 p-mos
SystemD_2kW, any interest for an open design?Hide this!Advertise here!
Probing interest in My inrush limiting design nattawa Power Supplies 5 8th October 2016 08:28 PM
O2 Front Panel INTEREST POLL your own design Llama16 Group Buys 1 12th September 2012 05:23 PM
Custom open baffle 12" woofer - any interest? SimontY Group Buys 2 4th March 2009 01:53 PM
Open baffle design lawbadman Multi-Way 1 17th January 2008 12:15 AM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 07:33 AM
