SystemD_2kW, any interest for an open design?
Old 26th September 2013, 07:12 PM   #431
ChocoHolic is offline ChocoHolic  Germany
Default Bridged operation
No surprises.
The first screen shot shows approx. 2kW into 4R.
The output voltage of 256Vpp translates to 91Vrms, which results in more than 2kW power.
Scale: 50V/grid (1:10 probe)
The second screen shot shows 2.3kW into 4R, close to clipping.
The output voltage of 272Vpp translates to 96Vrms, which results in 2.3kW power.
Drop of fs becomes visible.
The third screen shows 2.6kW into 4R, with massive clipping.
Due to rail sagging the peak voltage is even slightly less than at 2.3kW.
Increase of power is related to trapezoidal wave shape instead of a undistorted sinusodial shape, which lifts the RMS voltage without high peak values.
The measurements have been done manually with a sinusodial input signal.
The popular burst measurements with 300ms/700ms power/break would slightly lift the limits, but not much.
Old 26th September 2013, 09:09 PM   #432
Cresnet is offline Cresnet  Jordan
Very nice...
I noticed 0.000khz frequency on oscilloscope. is that normal?
Old 27th September 2013, 07:35 PM   #433
Yes, that's normal with this scope.
I stopped the scope and the amp before I took the picture.
Old 19th March 2014, 11:21 PM   #434
Stammheim is offline Stammheim  Germany
Hi guys,
as a kind of noob in electronics I thought for a while... at the end I'm happy to have made this decision and I'm proud to have built these wonderful amps.
I was looking for a while for some potential amps to power my woofers at 2Ohm. A clean sound and lowest distortion were absolutely essential.
After several nights of soldering and some support from Chocoholic (thanks a lot!!!) we could power the amps, which had a phantastic amplified output until almost 1,3kW @2Ohm.
Although the effort is high and the amp complex, I wonder why not more people have built this wonderful amp.
I hope, Chocoholic won't loose his pleasure and will design another fine amps in the future, which he hopefully will also share with us
Stammheim
Old 22nd March 2014, 12:07 PM   #435
Originally Posted by Stammheim View Post
... at the end I'm happy to have made this decision and I'm proud to have built these wonderful amps...
Again my congratulations.
It is a complex project and you made it almost free of errors!
And you helped to catch inconsistencies/mistakes in my documentation for V1.5.
I will double check again and then publish the builders pack of V1.5 .
Old 22nd March 2014, 02:41 PM   #436
Default Builders Pack of V1.5
...here it is..
Old 23rd March 2014, 10:56 AM   #437
Reactance is offline Reactance  South Africa
Reactance's Avatar
Originally Posted by ChocoHolic View Post
No surprises.
I feel bad for your neighbours
seriously good work, thanks for keeping the diy standards high. reminds me of eva`s work. does anyone know what happened to her ? or are the two of you working together in the silence.
There’s nothing worse than the smell of burned output transistors!!
Old 23rd March 2014, 11:12 AM   #438
pergo is offline pergo  Italy
pergo's Avatar
Is there any method to do hysteresis control with commercial OTAs?
One of these, for example: Transconductance Amplifier * - Products - TI.com
Nessuno può farvi sentire inferiori senza il vostro consenso
Mr.P Electronics
Old 23rd March 2014, 10:54 PM   #439
Basically it should work to take a constant hysteresis through
a voltage divider from the half bridge, then gain it through such a high speed OTA and when the speaker signal comes to large levels then reduce the gain by reducing the quiscient current.
However the nonlinear Iq control characteristic will need to be taken into account.
Originally Posted by Reactance View Post
...does anyone know what happened to her ?
Sadly I also lost the contact to Eva.
...would love to read of her again.
Old 24th March 2014, 08:49 AM   #440
luka is offline luka  Slovenia
luka's Avatar
I could try to contact her via messenger. Should i?
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
SystemD_2kW, any interest for an open design?Hide this!Advertise here!
Probing interest in My inrush limiting design nattawa Power Supplies 5 8th October 2016 08:28 PM
O2 Front Panel INTEREST POLL your own design Llama16 Group Buys 1 12th September 2012 05:23 PM
Custom open baffle 12" woofer - any interest? SimontY Group Buys 2 4th March 2009 01:53 PM
Open baffle design lawbadman Multi-Way 1 17th January 2008 12:15 AM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 07:33 AM
Copyright ©1999-2017 diyAudio
