SystemD_2kW, any interest for an open design?
Old 22nd March 2013, 09:53 AM   #351
Reactance is offline Reactance  South Africa
Reactance's Avatar
Originally Posted by ChocoHolic View Post
Measuring an amp is just half of the game. Listening to it is of same importance (or even more?). This design allows tons of variations of OP amps and comparators.
I would have expected that the comparators would play a dominant role for the sound, but to my ears the differences were just very marginal and sort of diffuse – still giving a personal preference on the MAX913.
The OP amps showed a stronger impact and they are changing the sonic character to the amp.
Here my ranking:
1. AD8620:
Very vital and voluminous. Impressive soundstage (despite being mono!) and surprising air. Details unlimited.
2. OPA 1612:
Also vital, but less voluminous. Less soundstage and gradually less air.
3. LT1364:
Vital, but shows no mercy with the shortcomings/harshness of internet radio and some poor MP3.
Pretty OK, when listening to a higher quality source like 192kHz flac.
4. OPA2134:
Very decent. Very comfortable. Not annoying at all. But for my taste sometimes slightly to thin.
5. LM4562:
Slightly pressed. Reducing the ease of music, giving it more a character of hard work.
6. NE5532:
Has similarities to LM4562 ( sorry TI/National guys, please don't shoot me..), but less contours.
In 1980 NE5532 must have been an amazing OP amp.
7. TL072:
Despite the fact that the amp is still working trouble free - the TL072 is the right choice to avoid audiophile satisfaction after spending a lot of efforts and money.
To me it was very surprising to find the character strongly influenced by the OP amps and less by the comparators. Also I would have expected the LM4562 somewhere in the Top3.
Chasing for a correlation between measurements and listening perception, I went for multiple comparative measurements of NE5532 vs AD8620, comparator was always MAX913.
To ensure that my measurements reflect a similar situation like my listening tests, I used the real speakers as load and performed the measurements at a similar level like listening ==> 4Vp.
First picture:
Again the list of alternative components
Second picture:
Spectral noise density
Third picture:
THD at 1kHz and 5kHz
Fourth picture:
Spectrum of 1kHz THD
Fifth picture:
IMD
Sixth picture:
IMD over frequency
Seventh picture:
Step response.
Both measurements in one picture by using the fluorescent storage of the scope. Amazing they equal even in each HF cycle!
By the end of the day I must admit:
Either I am a believer, or my measurements are not covering all relevant properties.
Im curious if you were blind folder-ed would you be able to make these statements ?
There’s nothing worse than the smell of burned output transistors!!
Old 22nd March 2013, 05:55 PM   #352
Tekko is offline Tekko
Banned
This is my interpretation of your Dynamic Hysteresis D-amp circuit.
Currently a simulation is running using a short wave file as the signal input, the output is beeing written as another wave file.
Old 22nd March 2013, 06:48 PM   #353
ChocoHolic is offline ChocoHolic  Germany
Double blind tests... definitely to much of an effort.
I am not even sure if I could tell the type in a single blind test.
The described sound characters are my perception from listening while I knew about the DUT. Strange enough that even there my perception was different from what my audisoteric opinionated mind told me before....
Sound is like gourmet food.
It tastes better when you can see it and it's looking nice.
There is no clue in killing subconsciously generated feelings, by blind tests.
Still I am doing blind tests once and a while. Unfortunately you always need a second person who is interested in the matter and agrees to spend time for the test.
My last blind test was with cables, because I wanted to prove to myself:You cannot hear it.
I had moved to a new apartment and had positioned the stereo set for an acceptable WAF ==> 12m speaker wires. Ignorant me did this with 2x1mm˛. The sound was alien, because of the new apartment, but not just alien, also annoying. For some silly reason I thought about the wires and changed the set up to shorter (3m) and multiple paralleled with 2x3x1mm˛.
Still alien, but less annoying.
In the blind test I had 10 correct out of 13.
From measurements and theory it should have been ignorable...
No it was not the bass which had changed, because of the damping factor.
The bass was unchanged to my ears.
Old 22nd March 2013, 07:12 PM   #354
Yup, I think you took it right.
Your power stage is different, so also your propagation delay (==> fs) and distortion figures may differ from my power stage. But basically it should fit.
WAV files?
You mean you are chasing music through your sim in order to listen to your sim? Playing the output WAV with your normal stereo?
That's a cool idea!!
Old 22nd March 2013, 08:11 PM   #355
Banned
Well yeah but its a slow process, about 100mS worth of audio takes about 10 hours.
My power stage is a little different as i only have spice models for the IR2110 and the others available at this site: ftp://kavcrl.dyndns.org/%2BMEDIA/exp...ym/yahoogroup/
I might try this out together with the UcD in my other post above and see if i can tell them apart from each other.
Old 22nd March 2013, 09:17 PM   #356
Old 23rd March 2013, 02:27 AM   #357
Workhorse is offline Workhorse
Workhorse's Avatar
Tekko is in serious mode Choco.......!!!!
Old 23rd March 2013, 09:35 AM   #358
Banned
Just for the fun of it, i did a sim with and without the dynamic hysteresis.
i did modify the circuit alittle toward the kinda voltages i was going to use and what zeners i have in stock.
Old 23rd March 2013, 10:02 AM   #359
Hi Tekko,
yes that's the way how it should act.
Nice to see that you use the idea to experiment with your own adjustments to fit voltages, components and personal taste.
I have to admit, I did not investigate in detail which adjustment I really prefer, but just stayed with one reasonable setting so far.
P.S.
I really like the idea to listen to a sim
Edit:
Which switching frequency do you get with your output stage?
Old 23rd March 2013, 10:09 AM   #360
Banned
390-450kHz with the values given in the pics in the post above.
SystemD_2kW, any interest for an open design?Hide this!Advertise here!
Probing interest in My inrush limiting design nattawa Power Supplies 5 8th October 2016 08:28 PM
O2 Front Panel INTEREST POLL your own design Llama16 Group Buys 1 12th September 2012 05:23 PM
Custom open baffle 12" woofer - any interest? SimontY Group Buys 2 4th March 2009 01:53 PM
Open baffle design lawbadman Multi-Way 1 17th January 2008 12:15 AM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 07:33 AM
Copyright ©1999-2017 diyAudio
