SystemD_2kW, any interest for an open design?
Old 24th February 2013, 08:44 AM   #291
Cresnet is offline Cresnet  Jordan
Thanks for the valuable informations, but I would like to know the power supply voltage!
Thanks!!!
Old 24th February 2013, 09:20 AM   #292
ChocoHolic is offline ChocoHolic  Germany
All shown measurements were done with the Hypex SMPS1200A700.
It is delivering +/- 83V during idle situation and is stiff enough to allow the amp to deliver about 1200W sinewaves into 2R.
Edit:
When you drive the amp into heavy clipping with 2R load, then the SMPS is shutting down at about 1.5kW.
IMHO for professional applications this SMPS is only making sense if you use a limiter, which avoids heavy clipping.
Old 24th February 2013, 09:41 AM   #293
Reactance is offline Reactance  South Africa
Reactance's Avatar
Edit:
You using a Hypex SMPS1200A700 nice.. do you use this as your bench powersupply.
JSP Page
sigh its like 150 Euro Thats = 150 * 11.67 = R1750.5
anyone here know of a cheaper type sypply with the same quality and specification ?
There’s nothing worse than the smell of burned output transistors!!
Old 24th February 2013, 10:49 AM   #294
...yes, the Hypex supplies are not cheap.
But to me they appear to be well designed.
Not regulated, no PFC, but still overall good.
Old 24th February 2013, 10:55 AM   #295
Edit:
And they are designed with synchronous rectifiers, so they are not suffering from supply rail pumping in unbridged applications.
Old 24th February 2013, 12:33 PM   #296
-Overvoltage protection is fine.
-Over current protection is shutting down at 40A, here still a lot of work ahead to verify the worst case situation in detail and adjust to 50A and verify that...
-With respect to Tom's question, here the measurements regarding the damping factor.
I used a traditional solid state amp and a low inductive resistor to feed sine waves with 20App into the output of the class D amp and kept the input of the class D amp shorted.
@20App
20Hz: Voltage impact on D amp = 27mVpp, Ri= 1.35mOhms, ==> 2R damping factor = 1481
50Hz: Voltage impact on D amp = 28mVpp, Ri= 1.4mOhms, ==> 2R damping factor = 1429
100Hz: Voltage impact on D amp = 28mVpp, Ri= 1.4mOhms, ==> 2R damping factor = 1429
200Hz: Voltage impact on D amp = 28mVpp, Ri= 1.4mOhms, ==> 2R damping factor = 1429
500Hz: Voltage impact on D amp = 27mVpp, Ri= 1.4mOhms, ==> 2R damping factor = 1481
1kHz: Voltage impact on D amp = 20mVpp, Ri= 1mOhms, ==> 2R damping factor = 2000
2kHz: Voltage impact on D amp = 40mVpp, Ri= 2mOhms, ==> 2R damping factor = 1000
5kHz: Voltage impact on D amp = 97mVpp, Ri= 4.85mOhms, ==> 2R damping factor = 412
10kHz: Voltage impact on D amp = 206mVpp, Ri= 10.3mOhms, ==> 2R damping factor =194
20kHz: Voltage impact on D amp = 533mVpp, Ri= 26.7mOhms, ==> 2R damping factor =75
Old 24th February 2013, 06:48 PM   #297
ViennaTom is offline ViennaTom
Strange that you have less output impedance at 1kHz than at 50Hz.
Old 24th February 2013, 08:26 PM   #298
...right - I also wondered about that and double checked the measurements and got identical readings.
But we have to consider that the output impedance is extremely low.
On purpose I showed the 2R damping factors, while normal marketing strategy would be to show the 8R damping factor only at 1kHz - which is 8000
Cool number, but perfectly meaningless.
Anyway, when measuring such low output impedances already the magnetic field of the load wires can easily induce signals to the input of the amp which lead to output signals larger than the signal you want to measure.
Even with optimized wire geometries there will be fields which induce into the amp input. Also fields from its internal layout tracks and voltage drops in the GND plane influence the damping factor.
Old 25th February 2013, 03:54 PM   #299
odnaizutra is offline odnaizutra  Guyana
nice done Choco ,great thread!
Old 26th February 2013, 06:52 PM   #300
dimitri is offline dimitri  United States
dimitri's Avatar
Send a message via ICQ to dimitri
Can the loop gain have correspondent bump at 1kHz?
SystemD_2kW, any interest for an open design?Hide this!Advertise here!
Probing interest in My inrush limiting design nattawa Power Supplies 5 8th October 2016 09:28 PM
O2 Front Panel INTEREST POLL your own design Llama16 Group Buys 1 12th September 2012 06:23 PM
Custom open baffle 12" woofer - any interest? SimontY Group Buys 2 4th March 2009 02:53 PM
Open baffle design lawbadman Multi-Way 1 17th January 2008 01:15 AM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 08:33 AM
Copyright ©1999-2017 diyAudio
