SystemD_2kW, any interest for an open design? - Page 43 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 2nd July 2013, 10:00 PM   #421
True. And the SystemD 2k4 offers symmetric input.
Old 5th August 2013, 09:24 PM   #422
..Dimitri's comments pushed my brain to the right direction.
I am sticking to my I-want-it-all requirements and consequently will get an undesired GND loop somewhere.
But when you wire both signal grounds to a star right at the RCA sockets, then the input amp will always automatically compensate the undesired voltage drops on the GND, no matter if used asymmetric (one RCA of each channel shorted) or symmetric.
The attached schematic shows the simplified principle without EMI filtering.
Old 7th August 2013, 07:52 PM   #423
...did I say unavoidable loop?
Nobody heavily complaining?
My brain blanked out the option as attached here, because I generally dislike a large geometric separation of signal wires and signal GND.
...and it messes my geometric separation of power GND and signal GND.
Fortunately my signal GND is close to the speaker power GND on the PCB and the PSU GND is not inbetween.
It will also suffer from adding to the signal the voltage drop of the GND connection between both amps, but will also benefit from the compensating effect of the input stage.
Nevertheless I am starting to think of this as a viable option, when routing the signal wires geometrically close to the GND connection.
Old 2nd September 2013, 09:31 PM   #424
Default V1dot5
Here an update on V1dot5, which is going to be the version for my living room.
- Speed:
In the first two pictures you can see the amp reproducing a 12kHz rectangle with +/-10V. First without load, then with 2R load.
==> No overshoot. Sloping times of approx. 3us
Voltage scale: 5V/div
Time scale: 10us/div
- Distortion / IMD:
See THD and IMD vs power in the table.
THD vs frequency in the graph (10W).
- Ability to reproduce complex signals with high fidelity:
AP2 often is pointing to complex music signals. Even when I doubt that you need unaffordable measurement equipment to analyse the amp with real music program - I am convinced that optimizing an amp for more complex signals pays back during listening.
A simple combination of a large triangular signal (1kHz) with superimposed rectangular signal (10kHz) can open your eyes on short comings in your design. V1dot5 showed good fidelity already from the beginning. After another analysis of the loop gain including all options to control dv/dt - the behavior of the amp brought a smile on my face.
Voltage scale: 20V/div
Time scale: 100us/div
Old 7th September 2013, 03:48 PM   #425
Triggered by another thread I analysed the noise and noticed that V1dot5 was wasting about 10db SNR, just by the symmetric input stage.
Unnecessary high impedances combined with LT1364 and unnecessary high gain.
So I changed to the AD8620 and reduced the impedances and the gain.
AD8620 gives one OP amp to the symmetric input gain stage and the second for the power amp itself.
Fortunately AD8620 is fast enough and provides mostly identical perfection in control, also the signal shaping for low THD remained fine.
The output noise is now 63uVrms (still dominated by the symmetric input gain stage), a value which is fully up to the mark with class AB amps.
Attached a screen shot of the spectral noise distributions at 1W and 1000W.
Also THD vs. frequency remained fine.
Attached a screen shot which displays K2+K3 in comparison to THD+noise. Power was 10W into 2R.
Old 7th September 2013, 06:49 PM   #426
Workhorse's Avatar
I am sticking to your thread as it raises the bar........Nice measurements and tweaks.
Congrats Choco.
Old 8th September 2013, 07:32 AM   #427
Baldin is offline Baldin  Denmark
Baldin's Avatar
Send a message via MSN to Baldin
Amazing .....
..... I subscribe to this thread just to learn
.... cool work Choco
Visit www.sensibleaudio.dk or read latest news on Baldin's Blog
Old 10th September 2013, 05:30 AM   #428
soc15 is offline soc15  Thailand
Default dymamic hysterisis
u can use limit input like
EP 1071215A1
Old 12th September 2013, 04:53 PM   #429
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Old 26th September 2013, 08:02 PM   #430
Default Dual mono in experimental enclosure
Why experimental?
-Heat sinks are larger than necessary.
-It is 2 units high, but 1.5 units would be sufficient.
-Wiring suffered from experimenting.
-A friend is considering to build the amp as well and go for a special enclosure, I kept the supply wiring longer than necessary in order to stay flexible for a potential transfer in a different enclosure.
Nevertheless, the set up is performing very well.
I tested both wirings (posting #422 & posting #423).
Both showed no issues with HF interactions between both channels.
The first wiring showed a slightly superior behavior in case of strong external magnetic fields. This can become relevant, when stacked directly on top of an ancient amp with monster transformers. So the wiring like in posting #422 is my final choice.
Even without top cover you can run the amp at full power without interfering a FM reciever close by.
Distortions and complex signal handling remained unchanged after implanting the amps into the housing.
You will notice four RCAs for each chanel, two for AC coupling and two for DC coupling.
For AC coupling I am using the Panasonic ECW series. Definitely one of the better choices, when staying with non audisoteric types. The Mundorfs which I used earlier where fine as well, but with 4u7 they would simply be to large for the PCB - while the Panasonics easily compete in sound and come at attractive size.
This allows all considerable input choices:
-DC coupled symmetric inverting, DC coupled symmetric non inverting DC coupled inverting, DC coupled non inverting, DC coupled bridged.
-AC coupled symmetric inverting, AC coupled symmetric inverting, AC coupled inverting, AC coupled non inverting, AC coupled bridged.
The sound? Detailed and decent at the same time. Unmatched bass control. ...and sound stage!!
Sound stage always is a hard to meet design goal. The design variations with this amp gave me some more insights - still no bullet proof recipe.
My friend must hurry up, the more I am listening to this amp the less I want to disassemble it...
Attached some photos of the nice guy.
Probing interest in My inrush limiting design nattawa Power Supplies 5 8th October 2016 09:28 PM
O2 Front Panel INTEREST POLL your own design Llama16 Group Buys 1 12th September 2012 06:23 PM
Custom open baffle 12" woofer - any interest? SimontY Group Buys 2 4th March 2009 02:53 PM
Open baffle design lawbadman Multi-Way 1 17th January 2008 01:15 AM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 08:33 AM
Copyright 1999-2017 diyAudio
