SystemD_2kW, any interest for an open design? - Page 16 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 8th December 2012, 09:15 PM   #151
Attached the updated schematics.
Power stage is now updated according discussion, manual calculation and simulation.
V0.1 is obviously more complex than V0.0, but with respect to the discussed
experiences of multiple friends here and finding the same result in my calculations, I am skipping the initial plan use the body diodes.
Qrr is simply to high and would lead to a less reliable design.
The bunch of small caps at the switching stage could theoretically be solved by two caps, but multiple small SMD caps will be fortunate to achieve low parasitic inductances in the layout.
Again looking forward to your valuable feedback.
P.S.
NIP means Not In Place, but intended as an option.
Old 8th December 2012, 09:39 PM   #152
Banned
Im trying to make sense of the two comparators in parallel beeing different types.
Is it that one is open emitter and the other open collector to form a totem pole output ?
I thought the LT1016/MAX913 type was already totme pole output rather than open collector/emitter.
Old 9th December 2012, 09:48 AM   #153
Have a look to posting #53
Old 10th December 2012, 01:16 PM   #154
Reactance's Avatar
I have question with the modulator configuration
Amplifier 1 (E1)
C315 = 110p
R166 = 15k ; sets the frequency response ?
r374 = 270k ; sets the overall gain ?
Amplifier 2 (E25)
Network A
E88 = 10n
R165 = 1.8k
C89 = 520p
R108 = 8.2K
R108 = 10R ; Forms a tuned circuit anyone help me figure out the calculated values here ?
Network B
R105 = 1K
C87 = 33NF
106 = 11K ; forms a delay help me figure out the calculated values here ?
There’s nothing worse than the smell of burned output transistors!!
Old 11th December 2012, 05:00 AM   #155
Charles has published his loop topology with AES and later here on DIYaudio.com.
Another post-filter NFB topology
Old 11th December 2012, 06:08 AM   #156
Reactance's Avatar
Thank you for the reference choc dude.
Old 11th December 2012, 07:08 PM   #157
If you want it as PDF just PM me.
If you want a printout with my signature you'd have to wait until April 2013 !
BTW: Whereabouts in CT do you live ?
Charles
Old 11th December 2012, 07:30 PM   #158
Reactance's Avatar
Charles
Send you a PM the jpeg version is a bit distorted and hard to read.
Old 11th December 2012, 08:21 PM   #159
Hi Reactance,
you're welcome.
Great that you are already in contact with Charles.
2 years ago I also had a short exchange with him about his loop topo.
It's always best to get the information directly from the originator.
Old 11th December 2012, 08:29 PM   #160
fredos is offline fredos  Canada
Hi choco... Take a look at this... maybe you will see same thing as me... :-) fgh40n60smd
Probing interest in My inrush limiting design nattawa Power Supplies 5 8th October 2016 08:28 PM
O2 Front Panel INTEREST POLL your own design Llama16 Group Buys 1 12th September 2012 05:23 PM
Custom open baffle 12" woofer - any interest? SimontY Group Buys 2 4th March 2009 01:53 PM
Open baffle design lawbadman Multi-Way 1 17th January 2008 12:15 AM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 07:33 AM
Copyright ©1999-2017 diyAudio
