SystemD_2kW, any interest for an open design? - Page 15 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 6th December 2012, 06:58 PM   #141
Hm, there seem to be not so many schottkys in TO-220, which are able to handle 60A or more, so I think I should keep the provision of TO-247 for the series shottky.
60CTTN015 (15V/60A/TO-220)
DSSK80-0025B (40V/80A/TO247)
MBR7030WT (30V/70A/TO247)
The freewheeling diode will need to carry high currents only at short duty cycles. Assuming worst case of a short, then it will be duty cycle of 50%.
Means a 30A type is sufficient. This diode should not be unnecessarily overbold, because its Qrr and/or capacitance is causing disturbances during switching.
Nevertheless in case of shottky technology also fat ones could be an option.
HFB35HB20C (200V/35A/TO-220)
HFB35HB20 (200V/35A/TO-220)
V30200C (200V/30A/TO-220, Shottky)
DSSK60-02A(200V/TO-247, Shottky)
Further proposals welcome.
Old 6th December 2012, 09:03 PM   #142
fredos is offline fredos  Canada
APT30D60BHB?
Old 7th December 2012, 07:11 AM   #143
Regarding posting #140:
Nobody pointing to the 100nH in the rails?
Nobody highlighting that the voltage across M4 is at the data sheet limit instead 160V-170V?
The 100nH are way to high for the planned currents and the energy which is stored L_track8 and L_track 11 is pushing the MosFet into avalanche and when the energy is burned down the high voltage will remain across the MosFet in OFF status because there is not discharge path.
...might still be inside the allowed avanlache range (not checked yet), but that are ugly unnecessary losses.
L_track8 & 11 must be designed to be much less ==> Layout!
Furtheron simulation is pointing to the direction that a very effective and low loss snubbering is possible by paralleling 1-10 Ohms to the shottkys, which are in series with the MosFets. Besides snubbering this also gives an discharge path after avalanche.
@Fredos:
That's a cool diode! 600V/60A and just 3times the Qrr of the HFB35HB20C.
Pretty amazing.
So far I am trying to stay with 200V-300V devices and Qrr<1uC (at 800A/us and 125C). But I agree, it would also work with your proposed diode.
Old 7th December 2012, 10:59 AM   #144
The simulation of the power stage with its parasitics will hopefully guide me through the layout and avoid relooping through hundrets of non working PCBs.
Nevertheless the layout will take time, because it will be an iterative process between sim, placing components, guessing parasitics - resim, replace components, reguess - reresim...
The sim is showing pretty detailed which component properties, which copper tracks, which snubbers, etc - will lead to different component stress and more or less ringing. By placing tracks and positioning components you really can change the behavior massively and not always it is the best to make every track as short as possible. Great! ...most likey I should also model the equivalent circuit of the ecaps...
Many thanks again to Tom and Workhorse. Upgrading the power stage with diodes, will not just make the design more reliable - it is also giving me a lot of design fun. Much better than rushing through the layout of a simplistic halfbridge, where I already did the fun part years ago.
Let's see how many PCB reloops will be necessary to get a satisfactory design, which is giving high performance and is rugged enough to be spread for DIY.
In any case -patience please, I am doing classD as a hobby and will not have always vacation like the last two days.
Old 7th December 2012, 11:20 AM   #145
baga is offline baga  Romania
What do you think about ST's tandem diodes? These are two 300V series connected diodes in an isolated package. Low Qrr!
Unfortunately STTH3006TPI is obsolete , but i think the lower current STTH1506TPI will work fine for this project.
http://www.st.com/internet/com/TECHN...CD00002947.pdf
Or MBR40250 Schottky 250v 40a to220 ?
And MBR60L45CTG 45v 60a to220 for series Schottky?
Old 7th December 2012, 11:25 AM   #146
This may be a good diode if your DC bus = 400V ~ 500 V (still not par to the carbide from switching speed), but with a 165V bus, this diode will not compete to 200V schottky.
Old 7th December 2012, 11:49 AM   #147
What do you think about a powerstage only with to220 devices? ipp110n20n3g , a mosfet with quite low capacitances for his low Rdson ,MBR40250 and MBR60L45CTG schottkies ?
Old 7th December 2012, 01:30 PM   #148
...very tempting triple...
Old 7th December 2012, 02:30 PM   #149
And this triple is available right away from digikey.
To much of temptation - you made me a victim of spontaneous Xmas shopping...
Nevertheless, I am considering to settle the layout in a way that it can comfort TO247 and TO220 as well (for the MosFet and series shottky). Of course this will not allow full benefit of the TO220-package, but I am confident that I'll find suitable layout for TO-247, which will automatically also allow to use TO-220.
...following the goal to create a design and PCB which is helpful for DIYers and basically allows qualified mods.
Old 8th December 2012, 03:15 PM   #150
...went on with snubber analysis and fundamental considerations about where and how to block the rails.
It turns out that fast rail blockers at two points are extremely helpful:
- Across both MosFets including both series shottkys (note: previous arrangement was at across both MosFets and shottky inbetween only)
- From the cathode of the upper freewheeling diode to the anode of the lower freewheeling diode.
These blocking caps can be center tapped to GND, but that's not mandatory.
For the concerned currents the values of the blocking caps must be in the range of multiple uF.
If all this fufilled the system behaves pretty calm already without snubbers.
The earlier simulated damping resistors across the series shottkys become completely unnecessary.
Attached the simulated schematic and wave forms.
The first wave forms show the behavior even without drain-source-snubbers.
The improvement with drain source snubbers is not necessary for functionality, but has the potential to pay back during EMI measurements.
Last edited by ChocoHolic; 8th December 2012 at 03:23 PM. Reason: ...corrected design requirements
Probing interest in My inrush limiting design nattawa Power Supplies 5 8th October 2016 08:28 PM
O2 Front Panel INTEREST POLL your own design Llama16 Group Buys 1 12th September 2012 05:23 PM
Custom open baffle 12" woofer - any interest? SimontY Group Buys 2 4th March 2009 01:53 PM
Open baffle design lawbadman Multi-Way 1 17th January 2008 12:15 AM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 07:33 AM
Copyright 1999-2017 diyAudio
