| Class D Switching Power Amplifiers and Power D/A conversion |
#61 | |
Musta been tricky not to have shorts with that stuff. IMO good chance you've damaged the Ta chip. Did similar when two speaker wires touched.. briefly. These don't suffer ineptitude.. gladly. IF you choose to Fix that thing, by inserting a fresh chip.. then DO wipe off the tone bits with a hot iron as they are Still in circuit. And those wee electro caps are unlikely to be adding goodness :-) |
#62 |
Bare
Does the wire thickness effect its ability to carry the signal properly? Or is there other reasons not to use such thick wire? It was no problem to solder and it did not short, it was the previous wire that caused the issue I think. OK thats about what I was guessing, I will get another chip and see how that goes. When you say wipe off, do you mean remove the components? |
#63 |
I just noticed that the left right channels are reversed when using 3.5 mm jack input. Is this a well known issue on 2020+? I couldn't figure out why imaging was so much better with RCA inputs until I noticed snare drums switching sides under a/b testing. What a fat blunder on the circuit!
#64 | |
#65 |
It sure does if you want to recreate soundstage, otherwise it is like stage is upside down, but worse, if true directional xy mic were used the presentation will be really off sounding. Think about it like a 3d movie viewed with the goggles swapped left to right, doesn't have 3d effect anymore.
#66 | |
#67 | |
Tube Amp builders - Getter Done! |
#68 |
I checked mine, and mine is fine (red board). What colour boards do you have that have it backwards?
Tyler |
#69 |
When I put a multimeter on the red (right) input of the RCA jack it connect to the left input on the 3.5 (MP3).
#70 |
I noticed that my blue A+ board has the channels swapped. I too was hearing the strange imaging. I hadn't checked the RCA's. I just swapped the speaker outputs to correct it.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine |
| TA2024 SA-36 or LP-2020A | Terrymm | Class D | 3 | 28th September 2012 04:34 PM |
| Help with Lepai LP-2020a+ | ChrisChris | Class D | 5 | 14th September 2012 03:24 PM |
| Lepai LP-2020A+ Balance Problem | Nightcry7 | Class D | 3 | 14th September 2012 03:16 PM |
| Lepai LP-2020 mod to include sub out | rziebro | Class D | 1 | 12th February 2011 03:01 PM |
| X-LP Mod Journey | pjpoes | Analogue Source | 2 | 11th March 2007 07:35 AM |
