LP-2020A+ mod thread
Old 29th April 2013, 12:51 AM   #221
THUMP LUMP is offline THUMP LUMP  United States
THUMP LUMP's Avatar
45 day "No Hassle Returns" for PE my ***. I have to call them for a RA number for a pathetic little $20.00 amp. On the other hand, I'm temped to diagnose and repair the problem myself just so I don't have to mess with PE at all.
Old 29th April 2013, 03:18 PM   #222
tamasic1 is offline tamasic1  United States
tamasic1's Avatar
Default Cigar box
Sorry your amp showed up bad. If you plan to diagnose it yourself, you might want to look at that output relay first. It keeps the speakers cut off for a few seconds at power on. You could try bypassing it.
Finished this yesterday. I took Tylerís advice and just used metal film PE caps. All were pulled from a large pcb I had in my parts bin. Large power cap is from same. If a smaller cap was used, this would have easily fit back in the case but I really like the looks of it in the cigar box. I didn't get fancy with gold connectors or toroid inductors. I plan to gift this to a family member along with a set of 2-way Dayton speakers.
Tube Amp builders - Getter Done!
Old 29th April 2013, 04:44 PM   #223
THUMP LUMP's Avatar
OK....PE have redeemed themselves. I called for the RA number and when "Stacy" realized it was just a small $20.00 amp, he said not to bother returning it and would ship out another today. I guess it's setup within their system that if it's an "electronic" item (as opposed to "electrical"), a RA number is required.
The up side is that I can play a good bit more with this first one a try to diagnose what is wrong with it. I'm still what I consider an "electronics noob" so this will help me learn a bit.
Old 29th April 2013, 09:09 PM   #224
tamasic1's Avatar
Default schematics
Download the TA2020-20 datasheet from the web. Combine the test circuit from the datasheet and Tyler's schematic from his op and you have the Lepai's layout.
Several people have commented that they would power up the unit and have no sound but if they let it sit for a period of time, 10~15mins or so, the sound would finally come through. (not just this version but older ones too) They would ether bypass or replace the relay.
Take the 4 screws off the front and slide the board out. Connect the power cable and switch it on. Do you hear a click from the relay? You should hear one within a secord or so after engaging the power switch. Very audible, you don't have to put your ear to it.
Old 30th April 2013, 12:09 AM   #225
THUMP LUMP's Avatar
I have had the datasheet for awhile. The relays on mine are just that, two separate ones on their own PCB soldered to the main PCB. I have not heard any clicking from them at all. I checked VCC at pins 22, 25, 27, 29 and that was all good. I believe the chip is bad because I didn't get any voltage coming out from pins 21, 23, 24, 26. Looks like I will be getting a new TA2020-020 chip from MCM unless anyone has anything else to check first. I need to order a compression driver from them anyway for a TalkBox I am building.
Old 30th April 2013, 02:48 AM   #226
THUMP LUMP's Avatar
I got tracing the relays and it looks like they are used to break the speaker grounds from the rest of the circuit until power is turned on. Could someone else confirm this?
Old 1st May 2013, 07:17 PM   #227
THUMP LUMP's Avatar
Got the replacement Lepai in today. Bone stock, right out of the box, I have to say, it lives up to the hype. That is, not bad at all for a $20.00 amp.
I am going to leave this one stock for the time being and mod/repair the first one probably beyond recognition (almost).
And I did answer my last question myself, after doing a bit more tracing to be sure. The relay does break the connection between the speaker neg. and the amp when the power is off. Regardless, I still do get a "thump", both turning it off and on.
Old 1st May 2013, 07:29 PM   #228
alejandrop89 is offline alejandrop89
Hi! im new here, saw this thread googling and think maybe any of you can help me, i've got this lepai and it's semi-broken now. When i turn it on, the right speaker do a weird thing and does not sound. It is not a problem of the speaker cos i changed it with the left one and it works. Here is a video of the problem, hoping if anyone know what happen and if i "mod" (change the capacitors) it will work again? Finally, i oppened it and everithing seems in good conditions.
(sorry for the yells, was football day)
Problema altavoces y ampli - YouTube
Thank you very much!
Old 2nd May 2013, 03:23 AM   #229
THUMP LUMP's Avatar
alejandrop89...Not sure what your problem may be other than it looks like your getting DC current to your speaker.
Old 2nd May 2013, 03:26 AM   #230
THUMP LUMP's Avatar
Managed to get the first one that was DOA stripped down today. I still need to get a TA2020 chip from MCM though. I did leave in all the output side components until later. This one will go into a custom enclosure.
LP-2020A+ mod threadHide this!Advertise here!
TA2024 SA-36 or LP-2020A Terrymm Class D 3 28th September 2012 04:34 PM
Help with Lepai LP-2020a+ ChrisChris Class D 5 14th September 2012 03:24 PM
Lepai LP-2020A+ Balance Problem Nightcry7 Class D 3 14th September 2012 03:16 PM
Lepai LP-2020 mod to include sub out rziebro Class D 1 12th February 2011 03:01 PM
X-LP Mod Journey pjpoes Analogue Source 2 11th March 2007 07:35 AM
