LP-2020A+ mod thread
Old 4th April 2013, 03:50 PM   #201
cogitech is offline cogitech  Canada
cogitech's Avatar
No. They only mention 4ohm and 8ohm configuration. Probably best to stick with the default values on your board in that case. I'm not qualified to make a judgement of what values to use or why to use such values.
Perhaps someone else around here is.
Old 4th April 2013, 05:33 PM   #202
Redshift187 is offline Redshift187  Canada
Originally Posted by Fukinagashi View Post
What is the role of the output caps (near the inductors) I see in the pictures?
Are they worth to be changed?
They are part of the low pass filter that turns the Class D output square wave into an audio signal. You could use better caps (film, as these are most likely ceramic), but stick with the values shown unless you know how to calculate the right values for your speakers.
Tyler
Old 5th April 2013, 01:41 AM   #203
tamasic1 is offline tamasic1  United States
tamasic1's Avatar
Default Cool PS
Originally Posted by sofaspud View Post
There was a change in plans.
I ended up taking the power supply I was using for a T-amp (an old Radio Shack #22-124; 2.5A/5A surge) and using that with the Lepai. Then I built a new supply for the T-amp.
Great! I try to source older, real iron transformers for a PS also.
Tube Amp builders - Getter Done!
Old 5th April 2013, 02:53 AM   #204
sofaspud is offline sofaspud  United States
sofaspud's Avatar
It's a pretty good unit. Common parts and the schematic is available online. Mine is all-original and still going strong at 35 years old. There's one on ebay now for a $25 bid including shipping.
I never met a power transformer I didn't like. I'll salvage 'em all, and have a few 5 gallon buckets full of different types.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 9th April 2013, 04:11 PM   #205
THUMP LUMP is offline THUMP LUMP  United States
THUMP LUMP's Avatar
Great Thread. I will be ordering one of these from PE soon and was wondering what are the most significant mods are so I can order what else I need from them at the same time, provided PE has what I will need.
Old 9th April 2013, 04:24 PM   #206
cogitech's Avatar
Just a small note to those who plan to heavily modify the Lepai:
If you plan to remove and/or bypass the volume and tone controls, and then spend some money on upgrading some other components, I suggest an alternative; buy this instead http://www.ebay.ca/itm/370738187019
It already has better components installed and it sounds fantastic compared to a stock Lepai, and it is basically the same price. Hook up your pre-amp of choice and Bob's your uncle. Sure you can still upgrade the main power cap to a bigger one and maybe stick in some POI input caps (I did both) but overall this is a better way to spend the 20 bucks and change, if you don't need the volume/tone and ugly chassis.
Old 9th April 2013, 04:59 PM   #207
Tekko is offline Tekko
Banned
The lepai amplifiers are so bad they are not even worth modifying, a much better value for money is the SMSL SA-S1 amp.
Old 9th April 2013, 05:44 PM   #208
THUMP LUMP's Avatar
While I appreciate the answers, I like to mod stuff and I also like to keep, what I can, of the U.S dollars I have in the U.S.
This little thing is going to be used only for background music from a laptop in my machine/fab shop. From what I am seeing at PE and what's available from them, it looks like I would have to get any mod parts from Mouser anyway.
Old 13th April 2013, 04:02 PM   #209
tamasic1's Avatar
Default Output caps
Is there a suggested value for a 6 ohm speaker?
The TA2020 datasheet application test circuit shows 4 or 8 ohm load can be used, however there is an asterisk beside the 8ohm. In the notes section under the circuit, it states:
* Use Co = 0.22μF and Cz=0.22uF for 8 Ohm loads
That being the case I would try .33uF for 6 ohm.
Make one mod to one channel then compare left to right.
Old 13th April 2013, 04:50 PM   #210
Bare is offline Bare  Canada
Well.. at least 'some' of the $ will go to 'muricans.
PE is only a reseller. Still a 'Made en Chine' lashup using fake components.
Although PE does give excellent service. Unlike Chinese Fleabay merchants.
IF after a cheapy? Hunt up a YJ ta 2020 amp on Fleabay.
Less Coin, also much reduced need to mod it as it's a much closer to the Tripath designed/suggested circuit.. than ANY lepai.. Box stock
LP-2020A+ mod threadHide this!Advertise here!
TA2024 SA-36 or LP-2020A Terrymm Class D 3 28th September 2012 04:34 PM
Help with Lepai LP-2020a+ ChrisChris Class D 5 14th September 2012 03:24 PM
Lepai LP-2020A+ Balance Problem Nightcry7 Class D 3 14th September 2012 03:16 PM
Lepai LP-2020 mod to include sub out rziebro Class D 1 12th February 2011 03:01 PM
X-LP Mod Journey pjpoes Analogue Source 2 11th March 2007 07:35 AM
