LP-2020A+ mod thread
Old 27th March 2013, 10:28 PM   #191
tp4tissue is offline tp4tissue  United States
What's the extra resistor for again?
Old 28th March 2013, 02:21 AM   #192
Redshift187 is offline Redshift187  Canada
You need a pair of resistors to set the input impedance and to make sure a voltage doesn't build up between the output caps of your source and input caps of your amp.
Tyler
Old 28th March 2013, 02:40 AM   #193
Bare is offline Bare  Canada
Imo :-) Inappropriate caps, the Goofy tone circuit is semi intact. The tone pots are still there . Did you physically remove the op amps (or One(?) on that earlier version board?
If not, they/it are Still impacting the sounds.. while the Resistors are IMO pointless.
But Hey! it's your amp .
Old 28th March 2013, 02:59 AM   #194
sofaspud is offline sofaspud  United States
sofaspud's Avatar
I've been wondering why it isn't just some traces cut and jumper wires placed from point A to point B. Desoldering practice?
But in the end it is pretty cheap DIY fun for those so inclined.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 28th March 2013, 12:34 PM   #195
Fukinagashi is offline Fukinagashi  Italy
R34, R35, R36, R37, C30, C31, C20 and C21 have been removed so the tone/pot circuit is completely out of the game...
Old 1st April 2013, 11:21 PM   #196
tamasic1 is offline tamasic1  United States
tamasic1's Avatar
Default power supply
Originally Posted by sofaspud View Post
I'm building a dedicated linear regulated supply for mine, so I may just remove and jumper that location.
Have you built one for this project yet? Curious as to what you used for a transformer. -thanks
Tube Amp builders - Getter Done!
Old 2nd April 2013, 12:43 AM   #197
sofaspud's Avatar
There was a change in plans.
I ended up taking the power supply I was using for a T-amp (an old Radio Shack #22-124; 2.5A/5A surge) and using that with the Lepai. Then I built a new supply for the T-amp.
If I needed to acquire something new for the power supply, I'd look for a 12VDC SMPS brick rated for 3 or 4 amps output, or a 12V 3A to 5A transformer for a linear supply.
Old 4th April 2013, 03:07 PM   #198
What is the role of the output caps (near the inductors) I see in the pictures?
Are they worth to be changed?
Old 4th April 2013, 03:13 PM   #199
cogitech is offline cogitech  Canada
cogitech's Avatar
AFAIK, they filter DC. But there is more going on than that, because the white paper specifies different cap values depending on impedance of speakers. See the white paper for details.
And yes, even if you just stick to the existing values, replacing with some polyprops is a great idea.
Old 4th April 2013, 03:15 PM   #200
Is there a suggested value for a 6 ohm speaker?
LP-2020A+ mod threadHide this!Advertise here!
TA2024 SA-36 or LP-2020A Terrymm Class D 3 28th September 2012 04:34 PM
Help with Lepai LP-2020a+ ChrisChris Class D 5 14th September 2012 03:24 PM
Lepai LP-2020A+ Balance Problem Nightcry7 Class D 3 14th September 2012 03:16 PM
Lepai LP-2020 mod to include sub out rziebro Class D 1 12th February 2011 03:01 PM
X-LP Mod Journey pjpoes Analogue Source 2 11th March 2007 07:35 AM
