LP-2020A+ mod thread
Old 21st March 2013, 02:59 AM   #181
tamasic1 is offline tamasic1  United States
tamasic1's Avatar
Default All out
Originally Posted by aj982 View Post
Haha. Nice.
I couldn't get myself to buy those cool looking Wimas...
Dude, go all out, PIO input caps, Wimas, Hell, Let's replace opamps with Burson modules. Burson Discrete Opamps
Tube Amp builders - Getter Done!
Old 21st March 2013, 04:01 AM   #182
tp4tissue is offline tp4tissue  United States
here I thought lm4562 were good
Now this... when will it end...
Old 21st March 2013, 11:30 AM   #183
danzz is offline danzz  Spain
A pair of 4562 are about 5$... A pair of the burson op-amp are 179$... I think its to much investment for a lepai... Im sure it worths in many other designs but a bit expansive for a 17$ amp... But good to know that those exist.
Old 21st March 2013, 11:49 AM   #184
Fukinagashi is offline Fukinagashi  Italy
Originally Posted by danzz View Post
No, I directly conected the iPhone as a source and some little speakers I made with some Tang Band w3 665SC I made for this purpouses...
But... would be safe to switch on the Lepai without any load or would be safer to use a couple of 6ohm 20W resistances?
I want to be sure there's no output DC before wiring the modded Lepai to my speakers!
Old 21st March 2013, 03:55 PM   #185
From the little I know those resistence shouldnt harm the amp If everything its ok, and measure the output...
Lets see what others that has lot more knowledge than me says...
Old 21st March 2013, 03:57 PM   #186
Redshift187 is offline Redshift187  Canada
Without a load is fine BUT, do NOT remove the load while the amp is on, many many people have fried it that way.
Tyler
Old 21st March 2013, 08:38 PM   #187
sofaspud is offline sofaspud  United States
sofaspud's Avatar
In general, it is better to test with a load. A pair of test speakers or the 6 ohm resistors. It completes the circuit. Without a dummy load, the meter itself becomes the (very high impedance) load when it is connected for a measurement.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 22nd March 2013, 10:29 AM   #188
Thanks. I did try this morning using a couple of 6ohm resistors.
I read few tens of mV DC without modifications.
Now I will try this basic mod:
1) remove C30, C31, C20 and C21.
2) wire C30 and C31 pads to C20 and C21 (right side) through a couple of 2.2uF caps (Clarity Caps).
and test again.
Old 22nd March 2013, 07:12 PM   #189
Keep in mind, typical DC or noise tests use the inputs shorted to ground, so they aren't floating. If you measured a few tens of mV DC with the inputs floating, then you can only expect a better measurement with the inputs grounded.
Tyler
Old 26th March 2013, 09:07 AM   #190
Here are my mods: two clarity caps as DC blockers and a couple of 10KOhm resistances in series to the signal (upper) as attenuators.
Two 47KOhm resistances as bypass (lower).
Thanks for help: despite the "minimal" modification the result is very interesting!
LP-2020A+ mod threadHide this!Advertise here!
TA2024 SA-36 or LP-2020A Terrymm Class D 3 28th September 2012 05:34 PM
Help with Lepai LP-2020a+ ChrisChris Class D 5 14th September 2012 04:24 PM
Lepai LP-2020A+ Balance Problem Nightcry7 Class D 3 14th September 2012 04:16 PM
Lepai LP-2020 mod to include sub out rziebro Class D 1 12th February 2011 04:01 PM
X-LP Mod Journey pjpoes Analogue Source 2 11th March 2007 08:35 AM
