LP-2020A+ mod thread - Page 18 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 18th March 2013, 01:21 PM   #171
Originally Posted by Fukinagashi View Post
After a while the resistors got very hot and then I measured about 12V DC at the outpus of the Lepai!
The only differences respect to original schematics is that I did not use any DC blocker as I'm sure that pre-amp has not any residual output DC.
Measure your pre-amp, don't guess! Then multiply what you measure by 20 and that's about what your speakers will see.
Where did you measure the outputs with respect to? + to - or + to ground? This is a bridged amp with a single supply, there's probably +12V on + AND - with respect to ground, which gives 0V between + and -.
Tyler
Old 18th March 2013, 02:52 PM   #172
Unfortunately I measured 12V on + AND -.
I've ordered another Lepai: in case I want to remove the pot should I get the signal directly from the RCA inputs or between R37 and R34?
Old 19th March 2013, 12:03 AM   #173
doesn't matter.. keep the decoupling caps to be safe I guess.
Old 19th March 2013, 01:13 AM   #174
Do not go from between R37 and R34. Either go from the pads on C30/C31, or straight from the input jacks.
Tyler
Old 19th March 2013, 12:47 PM   #175
danzz is offline danzz  Spain
Take a Look at the datasheet, there is a fault pin, check the voltage there, to be sure that the chip its gone... If its gone... You always can order only the TA2020 IC, and change it... It Will be always cheaper than ordering a new lepai... Its what I did with My first lepai that blew cause I desoldered without discharging the input big cap... And now I have that one working with a total tone/volume components removed ... And its has a great sound...
Old 20th March 2013, 12:39 AM   #176
danzz I see on the data sheet that fault pin is #18 but which voltage should I expect to exclude possible failures?
Old 20th March 2013, 04:49 AM   #177
From looking at the datasheet it says 5V for fault, and I would presume 0V for no fault.
Tyler
Old 20th March 2013, 11:14 AM   #178
Also can check pin 6 Which its the overloadb pin, you should have 5V in there as it says in the datasheet...
Overload
The OVERLOADB pin is a 5V logic output. When low, it indicates that the level of the input signal has overloaded the amplifier resulting in increased distortion at the output. The OVERLOADB signal can be used to control a distortion indicator light or LED through a simple buffer circuit.
About the fault pin...
Fault Pin
The FAULT pin is a 5V logic output that indicates various fault conditions within the device. These conditions include: low supply voltage, low charge pump voltage, low 5V regulator voltage, over current at any output, and junction temperature greater than approximately 155C. The FAULT output is capable of directly driving an LED through a series 2KΩ resistor. If the FAULT pin is connected directly to the MUTE input an automatic reset will occur in the event of an over-current condition.
Old 20th March 2013, 02:30 PM   #179
TX. I will try tonight. In the meanwhile the new Lepai arrived.
How did u tested the amp after mods? Did you shortened the inputs and the outputs before wiring the amp to the speakers?
Old 20th March 2013, 10:56 PM   #180
No, I directly conected the iPhone as a source and some little speakers I made with some Tang Band w3 665SC I made for this purpouses...
TA2024 SA-36 or LP-2020A Terrymm Class D 3 28th September 2012 05:34 PM
Help with Lepai LP-2020a+ ChrisChris Class D 5 14th September 2012 04:24 PM
Lepai LP-2020A+ Balance Problem Nightcry7 Class D 3 14th September 2012 04:16 PM
Lepai LP-2020 mod to include sub out rziebro Class D 1 12th February 2011 04:01 PM
X-LP Mod Journey pjpoes Analogue Source 2 11th March 2007 08:35 AM
Copyright 1999-2017 diyAudio
