LP-2020A+ mod thread
Old 10th March 2013, 04:59 AM   #121
tp4tissue is offline tp4tissue  United States
Originally Posted by Redshift187 View Post
Yes.
No.
The best thing you can do for more bass is increase the current your power supply produces. More voltage requires circuit components that are not on this board.
how do I m0ar current
Old 10th March 2013, 03:45 PM   #122
cogitech is offline cogitech  Canada
cogitech's Avatar
Tp4tissue,
Current = amperage
Buy a P/S with higher amperage rating. 5 amps aught to do it.
Old 10th March 2013, 03:54 PM   #123
cogitech's Avatar
On another note; two pieces of advice for all:
1) I was wrong to assume I should replace the 6 output caps with all .22uF. It sounded terrible. Major distortion even at low volume. Although I had also replaced the output inductors, but I doubt they were the culprit.
2) Always make sure you do a controlled discharge of the main power capacitor before you start removing and adding components. I bridged the cap contact point to something with my soldering iron yesterday, saw a nice spark while the volume LED glowed briefly and now -- dead amp.
Yes. I fry le Lepai. Glad it was only $20.
Old 10th March 2013, 03:56 PM   #124
Originally Posted by cogitech View Post
Tp4tissue,
Current = amperage
Hi Cogitech:
I currently do have the 12v, 5amp supply..
Do these tripath chips work anything like CPUs where more voltage makes them run "more stable"..
I'm not trying to overclock, , but I'm just wondering if the circuit would be "lean" with lower than the recommended 13.5v from the spec-sheet
Old 10th March 2013, 04:00 PM   #125
Ah.. scary.. thanks for that tip..
Um.. I was under the impression that these small capacitors "don't " need to be discharged...before desoldering.
Do I just take my car-light bulbs and bridge the gap while it's still on the Board to discharge it?
As for the capacitors... I suppose I could put most of the old stuff back, and then swap in things one "set" at a time.. to make sure it's working right?
Old 10th March 2013, 05:19 PM   #126
cogitech's Avatar
Originally Posted by tp4tissue View Post
Hi Cogitech:
I have seen people report good results with 13.5v supplies.
Old 10th March 2013, 05:22 PM   #127
cogitech's Avatar
Discharge them as you see fit. I use a resistor, when I remember to do it.
I do believe it makes sense to replace 1 thing (or a pair) at a time to see what happens. I am usually too impatient to do so, and I end up not knowing WTF is going on.
Old 11th March 2013, 01:38 AM   #128
What does the increased voltage do.. does the 12v I'm using impair function in any way?
Old 11th March 2013, 04:21 AM   #129
Redshift187 is offline Redshift187  Canada
What exact inductors did you use? Using 0.22uF caps is very unlikely to cause that much distortion.
I always unplug, then turn the power switch on and leave it on. Same with pretty much all other equipment. You can tell by the led around the volume knob when it's discharged.
Tyler
Old 11th March 2013, 03:56 PM   #130
^ this works..
also, yea the .22uf caps, it's in the spec sheet..
I swapped 2x Panasonic .47uf film back into the "left" channel.. in the C_o capacitor positions
Leaving the right channel all .22uf wima mkp10
Auditioning them separately.. via the speaker balance slider on my pc
I feel like the .22uf right has more detail.
Now I'm wondering if .33uf would be better because my ghetto cheap speakers are only 6ohm
LP-2020A+ mod threadHide this!Advertise here!
TA2024 SA-36 or LP-2020A Terrymm Class D 3 28th September 2012 04:34 PM
Help with Lepai LP-2020a+ ChrisChris Class D 5 14th September 2012 03:24 PM
Lepai LP-2020A+ Balance Problem Nightcry7 Class D 3 14th September 2012 03:16 PM
Lepai LP-2020 mod to include sub out rziebro Class D 1 12th February 2011 03:01 PM
X-LP Mod Journey pjpoes Analogue Source 2 11th March 2007 07:35 AM
