Go Back   Home > Forums > Amplifiers > Class D
Old 16th November 2012, 10:42 PM   #11
Bare is offline Bare  Canada
Just another Venerable Ta 2020 chip in a Flashy box.
At usurious pricings imo.
From the innards photos: A YJ at $15 is 'at least' it's equal.
Should be, as it uses Better quality bits/caps.
But No fancy extruded box nor Audio Weenie approved connectors.
I've a few Ta 2020's by now.. they are addictive... at less than $20 and/or $5 for the chip itself (delivered)
Replace the input caps AND use your ears, is best I can say.
I've experimented with $$$ ones and with Cheap 1$ films from the Local Chinese electronics shop. These cheapies Sound Better on the setup I experimented with.
Markedly better in fact. Very sweet, detailed highs. Curious result but well received.
Caps can/should be used as voicing tools.
What works best on someone else's setup ..does not.. necessarily work well / best on another. Cut 'n Try is required.
Inductors? Those supplied are of reasonable amperage, But as stated, replacements are easy and inexpensive experiments. I found no audible advantage.. But?
Output caps can be bettered for inconclusive results :-) YJ uses Wimas Does the K Rex?
Charge pump cap ..Should.. be a Good film and foil IMO, Fit one.
Dunno about the massive Power cap uf 'upgrade'.
It has proven of elusive improvement for me.
Real easy 'upgrade' though.
One day I will try the twin 180uf's as suggested by Tripath (what would they know?) using Decent Film Foils. That could be interesting.
G'luck
Ohh .. remember that this Ta2020 chip Will Not better a genuinely decent 'Old Skool' Amp sound wise. Despite all bleats to the contrary.
Maybe in the next generation or 2? chip designs.
How to fix Technics SB-T20 Speakers? Chellspecker Multi-Way 1 10th September 2012 08:53 PM
trends audio TA 10.1 audiomagus mod or Kingrex T20 Tripath amp andywhale Class D 5 17th February 2009 06:21 PM
King Rex Tech T20 Puffin Class D 42 21st October 2008 04:03 PM
Choice: two Trends T-10.1s or one Kingrex T20 w/PSU gnostic19 Class D 8 13th August 2007 06:50 AM
Technics SB-T20 The_Mox00 Multi-Way 2 10th November 2006 10:19 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
