Go Back   Home > Forums > Amplifiers > Class D
Old 10th November 2012, 08:38 AM   #1
ultra is offline ultra  Greece
ultra's Avatar
Default Powersoft K8
Hi all.
A Powersoft K8 came in for repair due to water damage.
Upon repairing a track on the underside of the pcb, i also found
a bad voltage regulator.
Unfortunately it is cracked open and i am not able to see which one is it.
I am referring to U4 in the power amplifier section.
Here is a pic that might help.
Old 11th November 2012, 04:53 PM   #2
gatabil is offline gatabil  Turkey
any have a service manual ?????
Old 12th November 2012, 09:17 PM   #3
tomi is offline tomi  Wales
Location: Aberystwyth and Manchester, depending upon term times.
You'll probably have thought of this, but is there an identical regulator doing the same job on the other channel?
I suppose looking at the voltage ratings of connected caps on the output would give you a ballpark idea of the o/p voltage.
I understand that powersoft are a bit cagey with their service data, unfortunately.
The Geek shall inherit the Earth.
Old 13th November 2012, 12:43 AM   #4
DjLeco is offline DjLeco  Romania
Send a message via Yahoo to DjLeco
U4 is LM7915, 15 volts negative regulator.
Old 14th November 2012, 12:24 AM   #5
ultra's Avatar
Thank you.
I think i came to the same conclusion myself.
There are only multilayer capacitors in the input and output of the regulator.
I only knew for sure it was a negative type.
Thanks again.
Old 14th November 2012, 01:18 AM   #6
Can you please make for me some GOOD QUALITY pictures of entire amplifier, divided in sections, from UP, so I can observe better what they do there?
Interesed to see inductor coils, output filters, storage capacitors, etc
Please sent on my email: claudiu971@yahoo.com
Thank you and good luck in repair!
Old 18th November 2012, 04:48 PM   #7
hi. if interested!!!
powersoft digam schematic d7000 link is...
Salida Digan 7000
Powersoft DigiMod series ? Lindell Class D 9 9th November 2012 02:46 AM
S5 K8-LM mono KIT (total newbie) barackuda Tubes / Valves 15 21st April 2011 01:37 AM
powersoft franklin1 Class D 0 18th February 2010 05:35 PM
PowerSoft Q3002 Robbo67 Class D 14 28th September 2009 03:20 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
