Are T amps just over hyped Distorting noise boxes? Or am I doing it wrong?
Old 23rd November 2012, 10:18 PM   #41
wmb is offline wmb  United States
Looking at the efficiency curves from some T-amp chips, it seems that using the parallel-resistor trick might not result in a substantial increase in power consumption. The efficiency curves look like "constant idle power with nearly all the dynamic power delivered to the load". If we assume that the average output power is rather less than 1 watt - as would be the case for high-efficiency speakers at moderate listening levels (say 85 dB), then the "wasted" power is maybe a watt across both channels.
So, while it would be "nicer" to re-tune the output filter, I'm having a hard time coming up with an serious downside to the 16-ohm shunt resistor hack.
Are T amps just over hyped Distorting noise boxes? Or am I doing it wrong?Hide this!Advertise here!
What is wrong with op-amps? Gordy Everything Else 4970 2nd June 2017 01:28 PM
Buss Channel with Noise after wrong soldered bypass Cap. suchenderxxx Analog Line Level 12 11th July 2012 09:58 PM
Wrong Voltage / current on BoZ... or Wrong Measuring ? gionag Pass Labs 8 14th May 2008 11:24 AM
Amps mounted on speaker boxes? mr__mcgoo Car Audio 6 10th June 2004 03:58 PM
What are the things that may go wrong with amps. downhere Solid State 1 9th December 2001 07:28 PM
Copyright ©1999-2017 diyAudio
