Go Back   Home > Forums > Amplifiers > Class D
Old 9th November 2012, 02:59 PM   #11
So if the rail is 2 x 84V and the amp consists of 2 full bridges, then it can be assumed that it can theoretically put out up to ~1600W into 8 Ohms per channel for very short bursts of a few ms duration. To put this in perspective, my XTI6002 (that is many times more expensive than iNuke) does clip at 144Vpk per channel into 8 Ohms, equal to 1300W bursts. The difference is that the iNuke cannot be bridged, assuming it is already 2 full bridges. And both channels into 4Ohms, the behringer can only sustain less that 1500W /ch. From my XTI6002, I have pulled 2 x 2200W (or 1 x 4500W into 8Ohms), it's PSU can suck >23Amps from the 230V supply and convert it.
Definitely not bad for the iNuke!!
Old 9th November 2012, 07:11 PM   #12
Plugged in the I-Nuke and it sounds like a hairdryer compared to my Crown XLS. This not a problem with livesound but you would probably want to do a fan/shroud mod for home use.
The peak limiters are new for me, anyone know how I should set them up for a pair of 3015Kappalites in large 5cft boxes vented @ 40hz?
I will be running the amp in either 2 x 8ohm mode with the kappalites or using the kappas on one channel at 4ohms and a 8ohm load on the other.
noob question :/ stenwo123 PA Systems 3 8th September 2012 01:28 AM
Seeking clarification of noob level questions. GestaltH Multi-Way 20 20th March 2008 12:20 PM
speaker level input vs line level question crippledchicken Subwoofers 4 17th July 2007 03:36 AM
iteration limit reached: another numb noob Q Onvinyl Everything Else 3 9th March 2006 09:55 AM
DIY line level schematic... noob here benhart007 Car Audio 3 4th February 2006 05:33 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
