Go Back   Home > Forums > Amplifiers > Class D
Old 5th November 2012, 04:13 PM   #1
Default Tripath 2022 amp
I have just purchased a Tripath 2022 amp of ebay. Layout diagram attached. A little confused about powering the board. It mentions an AC Dual supply of between 15-24v, not quite sure what the dual bit means, is this two power supplies? I suppose it should probably be a toroidal transformer rated at around 24volts, the more current the better! It appears that the board has a retifier present. I notice from a few threads that some people use laptop power supplies for the TriPath amps. I have loads of these knocking around. Could I use one rated at 20v 4.51 amps for this board? If so, how would I connect it to the AC power terminals on the board. Not entirely sure but if you put DC into a retifier you get DC out minus some volts due to the diodes, is this true?
Thanks.
Old 5th November 2012, 04:27 PM   #2
Google split supplies.
The point of life is to build atleast one audio amplifier before you die.
Old 6th November 2012, 04:01 PM   #3
activexp's Avatar
Send a message via ICQ to activexp Send a message via AIM to activexp Send a message via MSN to activexp Send a message via Yahoo to activexp
Check out my TA2022 build project here
I would suggest you use a 2 x 22V transformer rated at 225VA rather than the 2 x 24V 300VA I used.
Old 6th November 2012, 04:26 PM   #4
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
Yes, use a 2x22V transformer. That's as high as you want to go.
Old 7th November 2012, 01:47 PM   #5
How would I wire the 2x22v transformer to give me the dual AC input the board requires?
Nice project and thanks for the info.
Thanks.
Old 8th November 2012, 02:02 PM   #6
activexp's Avatar
There'll be a wiring diagram with the transformer. Can't really say much more until you get your hands on one. In the meantime research transformer wiring. Google is your friend
FS:TRIPATH TA-2022 amp board fpalotas Vendor's Bazaar 0 17th June 2010 12:23 PM
f/s Hlly t-90 tripath 2022 amp mfong Swap Meet 4 9th April 2010 12:55 AM
Resistors burned up on Tripath 2022 kit ozerik Chip Amps 1 3rd August 2009 11:19 PM
tripath 2022 kit snivit Digital Source 1 14th June 2005 09:11 PM
class t 2022 tripath snivit Class D 0 7th May 2005 10:26 PM
Copyright ©1999-2013 diyAudio
