what class-D amps can run off of +/-90VDC rails?
I have the luck of recently purchasing some beefy transformers that can be used in a linear power supply which will result in rail voltages of +/-89VDC. I'm looking for candidates for these amp boards, which I plan to use the amps 8-ohm subwoofers. Unfortunately, this is above the recommended rail range for most of the class-D amps that I have seen. I'd prefer class-D because power dissipation in class AB is going to be too much for my application.
So far I have identified ONE viable candidate: The ColdAmp Sonora S750:
https://www.coldamp.com/store/sonora-s750.html
This amp is spec'd to run on rail as high as +/-94VDC, so I have a couple of volts to spare. This amp can produce about 400W into 8 ohms, which would work well for me.
Any other class-D amp boards out there that will work? Any thoughts on these new Sonora products from ColdAmp?
-Charlie
How about this full wave cct.
Review the pdf on catalog page 11 (page 13 pdf pages)
Try it, you might like it.
Hi CharlieLaub
greetings will a diy class d amp operating at +/- 90 be ok for you only
thing you will have to etch your pcb
warm regards
andrew lebon
What is your suggestion for this "DIY Class-D amp"? I can design PCBs but I don't really want to spend the effort to do that for only a couple of units. I'm looking for off-the-shelf amp modules that I can power. Thanks
-Charlie
Joined 2004
I have a RA-2500 module that you are welcome to have for free (the price for anyone else is $40 plus shipping). The PCB layout for the amp that uses this module is available at: RB-TDA2500-1 datasheet and application note, data sheet, circuit, pdf, cross reference | Datasheet Archive
Occasionally the PCB's show up on eBay, but I didn't see any right now.
This is the link to the module:
http://www.profusionplc.com/images/data sheets/ra-2500.pdf
Hi Neil,
I read the datasheet and it seems it's just a driver IC/board and you need to have a handful of additional components (like the output stage) to create an amplifier... is that correct? If so, I am looking for something that is a little more plug and play...
-Charlie
Bringing this thread up again, in case some new stuff is out there...
I am currently thinking of buying a couple of these amp boards:
http://www.diyaudio.com/forums/vend...-500w-rms-class-d-subwoofer-pa-amplifier.html
They are available as of now, but I'm currently waiting to see if the designer will build one and post some testing results of THD, noise floor, etc.
Is there currently anything else out there that is class-D and runs (safely) off of +/-85-90V rails?
-Charlie
