Assembling TK2050 Kit
Old 7th November 2012, 03:25 PM   #11
Sofus2 is offline Sofus2
Default Not btl but paralelling?
Thank you Virpz for letting us know how to "BTL" this thing via the scematic (is it for the 2.2-version?) I bougt one of these boards cheap(est?) from goodluckbuy two months ago. It lasted some time and suddenly went up in smoke for no obvious reason. Apart from a little soldering and moddin... Maybe it has to do with the strange warning about "Europe" and voltage. But I used only 20 volts and 8 ohm. BTL it is alrady, but actually it is paralelling the two channels one have to do to get 100w and/or if one uses 4 ohm. It seems I must open all the shorted jumpers and vice verca?
I have bougt a already paralelled duoble 2050 board from Sure (on sale now 29$!!!)so I know the chip sounds much better than ANY AMP I'VE EVER HEARD!
Old 24th November 2012, 02:39 PM   #12
namronkire is offline namronkire
I messed it up.
Soldering the caps and resistors worked much better than expected, but I wasn't carful enought with the TK2050 and bent some of the contacts whe using the desoldering braid. When I tried to straighten them one by one I ripped a contactplate on the board off.
It was a interresting experience soldering SMD parts, but for ICs I need some more practice.
So is there any shop, where i can get such a board assembled, tested and ready to use?
Norman
Old 25th November 2012, 06:42 AM   #13
Mooly's Avatar
You need to prectice with SMD soldering. If the damage isn't to bad then it can be repaired with fine wire.
http://www.diyaudio.com/forums/parts...sed-tools.html
Old 25th November 2012, 07:57 PM   #14
Thanks for the tut, but it's too late. I got mad and broke the board in half.
Anybody knows any other source for such boards or any other solution for 24V and over 50W per channel?
Assembling TK2050 KitHide this!Advertise here!
Powering Remote control kit for TK2050 Billyo Class D 0 22nd April 2012 08:01 AM
Kef 105.3 assembling sandor626 Multi-Way 44 17th September 2010 10:09 AM
Tried assembling my own crossover...why didn't it work? PoorSound Multi-Way 5 16th February 2008 07:02 PM
Finishing assembling a driver? Destroyer OS Subwoofers 7 10th January 2006 10:12 PM
Assembling Neutrik Connectors soundNERD Parts 10 19th April 2005 02:15 AM
