Go Back   Home > Forums > Amplifiers > Class D
Old 31st October 2012, 09:35 AM   #1
smscad is offline smscad  Australia
Default Small Portable Weatherproof Speaker
Hi all,
I want to make a portable weatherproof speaker. I plan to use the Tripath TA2020 Amplifier that will be powered by a 12V 7ah SLA battery. I have found these waterproof speakers that I was planning on using. The speaker needs to be weatherproof as I want to be able to mount it on a bike rack for our tandem bike, use it by the pool and while camping.
I would like some advice on whether these speakers are appropriate to use with this amplifier. Is 4 ohm better than 8ohm in this case? Do I need any tweeters?
I have come up with a rough housing shape. I want to be able to have the speaker be able to sit flat or in a vertical position. Is the housing large enough? Should I keep the battery compartment separate from the speaker housing? I have attached a drawing of what I am thinking.
Any help would be greatly appreciated.
Simon
Amplifier
Tripath TA2020 PCB 25Watt Class-T Audio Amplifier Board | eBay
Battery specs
7.2 Amp Hour 12V Sealed Lead Acid Battery - Jaycar Electronics
Speakers
FR 13 WP Black - 4 Ohm
Old 1st November 2012, 12:36 AM   #2
Seems like those speakers are weatherproof on "both" sides, with fully encased magnet etc. it also is weatherproof on the back side. It might be overkill for you if you build the box well sealed, since there are a variety of regular speakers that are more or less weatherproof on the front and would give you a better bang for the buck.
For the TA2020 chip 4 Ohms gives more output but 8 Ohm slightly better efficiency for the amp. I think 4 Ohms are generally preferred for that amp/chip.
For a portable speaker I do recommend tweeters, since listeners are generally never on-axis. (Full-range speakers does generally not spread high freqs very good.) It is of course a matter of taste since tweeters increase the complexity, cost and so on.
Old 1st November 2012, 12:59 AM   #3
Thanks for the reply Mr Duke.
The speaker information says "IP protection class for front side when built into a sealed enclosure" so I think it is only the front that is waterproof. I need to find a speaker available in Australia. There doesn't appear to be a great deal of variety that I can find. Do you have a suggestion for tweeter size or type?
How do I know how big the enclosure should be for this speaker. I want to make sure the enclosure size is suitable. Should both speakers be in the same space or do they need to be kept separate?
Old 1st November 2012, 02:08 AM   #4
Bare is offline Bare  Canada
Earbuds! Skull Candy brand..if You can afford those :-)
Old 1st November 2012, 02:36 AM   #5
katana2112's Avatar
How about boat speakers?
NEW Bazooka MAC6502B 2-Way 6.5" Marine Audio Speakers Black (Pair) | eBay
Just a thought.....
Aggressively Passive
Old 1st November 2012, 03:14 AM   #6
@Kantana
The speaker I originally specified is for a marine application.
@Bare
I want to include some other features besides the speakers ie charge phone while playing music, that earbuds can't do. It was worth suggesting though :-)
Old 2nd November 2012, 12:38 AM   #7
OK, got it but my point was only that most regular speakers can take quite some "weather abuse" before actually breaking. Have you read the Boominator thread here on the forum? That design uses just treated paper cones and is used it some of the most gnarly, rainy rock festivals you will find... How weatherproof are you really looking at?
Just make sure it has higher sensitivity than the woofers so you can attenuate it to the right level. You don't want to attenuate the woofer! And make sure it has wide dispersion, like not variants with deep waveguides or horns.
Download winISD or similar modeling SW and put in the T/S parameters of the woofers. There are guides how to do this, just google it. I would say keep them in separate volumes...
Old 5th November 2012, 01:34 AM   #8
Found another speaker. From my reading of the boominator thread it sounds like the higher the efficiency the better.
Would this be suitable for the Tripath amp. I wasn't sure if the rated power of 20W is to low to be used with the tripath amp.
R 10 S - 4 Ohm
Old 7th November 2012, 07:44 AM   #9
R 10 S - 4 Ohm
Yep efficiency is very important for how loud you can go with the limited power a battery based and portable system can provide you with.
The speaker you link to is probably pretty crappy, the freq chat show huge in-linearities in response and the FS is high (180Hz) meaning you will have no bass.
I don't have any experience of it, but a lot of people have reported good results with the SP-60/4 or SP-60/8 from Monacor. It needs a tweeter though.
I am just finalizing a portable speaker with the NS3 from aurasound. Please note that it is not very loud, that is not the purpose of that one: Completed micro-boombox with TA2020
I think you need to find a proper diy hifi store to start with, seems other Aussies solves it by shipping in from overseas:
Does anyone know where to buy speakers drivers (and subs) in Australia?
Old 7th November 2012, 09:10 AM   #10
OK, I think I'm getting the hang of reading these charts now.
Would this be a better combination
http://www.essentialaudio.com.au/pdf...C9FD-18-08.pdf
http://www.essentialaudio.com.au/pdf...C25SC55-04.pdf
I don't think I'll worry about trying to waterproof.
If they are alright then I have a couple of questions.
Do they need separate enclosures or do the tweeter and driver go in the same enclosure?
How do I know what to use as the crossover?
Small Portable 3" Speaker? Entreated Everything Else 1 10th August 2012 06:32 PM
Small and portable headphone amp Crisis firefart_1st Headphone Systems 15 26th May 2010 08:24 PM
Any recommendation for outdoor weatherproof speaker connectors? swechsler Multi-Way 3 27th August 2008 05:46 AM
small driver for portable speakers _atari_ Full Range 7 15th May 2008 01:04 PM
Small Portable Speakers and a T-Amp guitarobert Full Range 2 24th January 2008 06:40 PM
Copyright ©1999-2013 diyAudio
