Small Portable Weatherproof Speaker
Old 8th November 2012, 01:48 AM   #11
mrduke is offline mrduke
Just reading the specs and not simulating it, I think those drivers start to look ok. However, you might want to think about your design preferences before ordering and designing crossovers. For example, how big can the box be, and do you prefer ported ("more" bass but bigger box) or sealed ("less" bass but smaller enclosure without holes in) design.
How large is the internal volume of the box you was planning for?
Also, how loud do you want it to be? 86 db/1W is ok but not stunning.
The tweeter does not need a enclosure at all, but it is most convenient to mount it in the same one as the woofer. Mostly because you want somewhere to hide the cables, and positioning is tricky otherwise ;-)
No seriously, it goes in the same enclosure as the woofer.
Old 8th November 2012, 02:01 AM   #12
smscad is offline smscad  Australia
I'm looking at about a 2.5L enclosure each side. I was thinking sealed but am open to suggestions. My overall design is about 150x150x300
Is 86 db/1W to low. Would I be wise to look for a higher sensitivity say around 90 db/1W. I've really got no idea how loud that is.
Old 8th November 2012, 02:14 AM   #13
I simulated the Vifa driver in winISD with 2 liter (per driver) sealed enclosure. Something like that should be ok. Qtc is close to 1, and F3 is about 122 Hz.
Old 8th November 2012, 03:43 AM   #14
Ah did not see your last message. 2.5 liters if good too. Gives slightly lower Qtc and F3 which is good. Those speakers works best in sealed design.
90 dB/1W would mean that the setup would be more than twice as loud.
With 86 dB/1W, 8 Ohm speakers and a TA2020 chip you would reach something like 98 dB at full blast, perhaps a little more.
I would say it is enough for normal to loud music listening, bbq etc, but not loud enough to have drunken all-out party. Maybe indoors...
Old 13th November 2012, 08:08 PM   #15
Received the amp yesterday.
Old 13th November 2012, 09:39 PM   #16
diyAudio Member RIP
The Vifa fullrange doesn't need an additional tweeter, use it on its own.
rgds, sreten.
Old 14th November 2012, 07:40 PM   #17
Thanks sreten,
I'm thinking that just the driver without tweeters may be my best option as it is my first build.
Small Portable Weatherproof SpeakerHide this!Advertise here!
Small Portable 3" Speaker? Entreated Everything Else 3 23rd May 2013 03:08 PM
Small and portable headphone amp Crisis firefart_1st Headphone Systems 15 26th May 2010 08:24 PM
Any recommendation for outdoor weatherproof speaker connectors? swechsler Multi-Way 3 27th August 2008 05:46 AM
small driver for portable speakers _atari_ Full Range 7 15th May 2008 01:04 PM
Small Portable Speakers and a T-Amp guitarobert Full Range 2 24th January 2008 06:40 PM
Copyright ©1999-2017 diyAudio
