guide me to make a active subwoofer in class d amp
Greetings
You have made a request to make two separate projects.
1. Subwoofer
2. Amplifier
There is lots of information in diyaudio for both projects.
Search and read, then think about what you want to end up with and what you have to work with.
Learn well.
hi,there are many reference in this forums,if you want to be a good class D design or diyer,you can refer to my thread,i am sure you will gain somethings~~
http://www.diyaudio.com/forums/clas...ass-d-amplifier-lets-make-class-d-easier.html
hi,
greetin,
first i sellect irs2092 class d audio but irs2092 is expensive its indian money is 400 ruppes so then i try irs500, the amp is ok then the problem is power supply and crossover desing for this amp. pls gudie to desing crossover.
BLOCK DIAGRAM SUB FILTER
GOOD FILTER
