Compact TDA8920-amp easy to bridge
Old 26th October 2012, 04:52 PM   #1
Sofus2 is offline Sofus2
Default Compact TDA8920-amp easy to bridge
Just move r31 and r37 to the left!
Old 26th October 2012, 05:31 PM   #2
-then the input on one vhannel is inverted - and simsalabim 200 watts (8 ohm!). you can probably even add a pair of 8 ohms in addition. Use this setup: BTL sub plus (non BTL) stereo - use crossover (coil for sub and caps for sattelites) and mind the reversed phase on one channel)
Old 26th October 2012, 05:39 PM   #3
Maybe use only 2x20v (dc) with this (chinese/"fake"?) chip
http://www.ebay.com/itm/290778321038...utput D | eBay
Old 20th June 2013, 04:09 AM   #4
6T5Gt0 is offline 6T5Gt0
does this board have an on/off switch
Compact TDA8920-amp easy to bridgeHide this!Advertise here!
TDA8920 complete amp...Cheap! fredos Class D 2 7th July 2009 12:09 PM
How easy is it to bridge vs parallel? Ulew Chip Amps 16 1st February 2009 12:53 PM
TDA8920 based amp module theAnonymous1 Class D 9 2nd January 2007 09:23 PM
Easy bridge carlosfm Chip Amps 9 12th December 2003 09:53 AM
