Which T-amp for Dynaudio bm15p Studio Monitors - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 17th October 2012, 07:06 AM   #1
Default Which T-amp for Dynaudio bm15p Studio Monitors
I search for the best option to power Dynaudio bm15p monitors.
This monitors are not very evicient.
Relevant monitor specs are:
IEC Long term powerhandling 250W
IEC Short term powerhandling >1000W
Sensitivity 88 dB
Impedance Nominal 4 ohm
Impedance HF (200 kHz) 5,9 ohm(what does that mean?)
I want to buy one of the hifimediy amps for this but i am not shure which one is better.
1)This one has 2x100W@4Ohm:
Hifimediy T2 SE STA510A MUNDORF MCAP
2)This one has 2x300W@4ohm
Hifimediy T3S mcap
Id love to hear your opinions!
With kind regards,
Manuel
Old 17th October 2012, 11:47 AM   #2
diyAudio Member RIP
The big one for a studio, smaller one possibly for domestic use, rgds, sreten.
Old 17th October 2012, 12:14 PM   #3
Jamesblond's Avatar
Might be useful to know that the tweeter (D260) can take some 130Watts RMS.
Old 17th October 2012, 12:21 PM   #4
diyAudio Member RIP
Hi, No it can't, not in a month of Sundays, rgds, sreten.
130W rms probably refers to wideband pink noise through a standard filter to the tweeter.
Old 17th October 2012, 06:10 PM   #5
Thanks for your answeres!
I also think I will get the T3s with mcap from Hifimediy.
Then i have two questiones about it.
1.)I will need to adjust the volume, and there is no pot. What kind of pot do i need to buy for this, and is it difficoult to solder it in?
2.)And what powersupply should i get?
I heared good things about this Meanwell:
Meanwell NES 350W 48V
And I heared this one is also good:
SMPS300R 48V 110V power supply
Would the two fit?
With kind regards,
Manuel
Old 20th October 2012, 11:27 AM   #6
Jamesblond's Avatar
Hi Sreten.
The figure I quoted comes from the Dynaudio D-260 spec sheet. It says that it can handle 130Watts and 1kW peaks (10ms). Seems high. But then again: my experience to date with Dynaudio is that it can take some real abuse before compressing or overloading. No idea about real world wattage numbers, though.
Old 20th October 2012, 11:54 AM   #7
diyAudio Member RIP
Hi Sreten.
130W rms refers to wideband pink noise through a standard filter to the tweeter.
Old 1st November 2012, 11:02 AM   #8
I m looking for same thing , powering a passive studio monitor with diy amp but i m more interested in A class rather than D class , but I m still searchin about that , I m not sure if you need a preamp or a buffer before your amp, better ask the guys around here for that , and how are you gonna connect it to your interface ? I think if you r goin to use Balanced output from your audio interface it s better if you use a balanced/unbalanced converter , i m not sure about that either just to keep that in mind and ask the guys about that as well , I ll be glad if somebody answer these questions
Marge, don't discourage the boy! Weaseling out of things is important to learn. It's what separates us from the animals! Except the weasel.
Old 3rd November 2012, 10:19 PM   #9
Hi Ahmad,
thanks for your reply and good questiones.
I thought I could use a balanced Audiocard and make a cable where one side is balanced and the other one just mono with one signal unconnected.
Would be glad if someone could confirm, íf thats allright....:-)
Cheers
Old 5th November 2012, 03:06 PM   #10
I found this on net to connect a balanced to unbalanced input but still i think it needs a preamp ,hope somebody can answer that
Fane Studio 5M+5FR - in use by which commercial Studio Monitors ?? tiefbassuebertr Full Range 9 2nd May 2015 08:13 AM
studio monitors bluezzman Multi-Way 8 8th August 2010 06:09 PM
Studio Monitors with LF under 10" stax Multi-Way 2 31st July 2009 02:20 PM
FS: KRK 6000 passive studio monitors & BNIB Antec P160 computer case Spasticteapot Swap Meet 0 10th July 2009 07:41 PM
Studio Monitors argonrepublic Chip Amps 5 27th May 2005 09:43 AM
Copyright ©1999-2017 diyAudio
